International Communities of Invention and Innovation IFIP WG 9.7 International Conference on the History of Computing, HC 2016 Brooklyn, NY, USA, May 25-29, 2016
Abstract : This paper presents an argument that the OSI proposed standard is technically superior to the TCP/IP standard for network communications. An Actor-Network Theory approach is taken for analysis of the historical record surrounding the adoption of TCP/IP. The paper does not seek to create a new history of TCP/IP but to suggest this is a case where traditional explanations of adoption based on the nature of the technology do not explain the demise of the OSI model. Parallels are then drawn between this adoption and the possible problems with the implementation of IPV6. These parallels provide insight into the impediments that may arise with the adoption of the new standard.
https://hal.inria.fr/hal-01620133 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, October 20, 2017 - 11:07:02 AM Last modification on : Tuesday, December 10, 2019 - 1:44:03 PM Long-term archiving on: : Sunday, January 21, 2018 - 1:06:03 PM
Bill Davey, Robert Houghton. Why not OSI?. IFIP International Conference on the History of Computing (HC), May 2016, Brooklyn, NY, United States. pp.115-121, ⟨10.1007/978-3-319-49463-0_8⟩. ⟨hal-01620133⟩
