Measuring an Impact of Block-Based Language in Introductory Programming
Abstract : The use of block-based visual language in introductory programming is a popular method in education. However, there is little research which provides evidence showing advantages of block-based language. This paper presents the results of learning data analysis with fine grain logs recorded by students’ development environment where the students can select their language in block-based or Java. A total of 400+ students’ logs collected each of four years were analyzed. The results show that migration from Block to Java can be consistently seen each year, although the whole block-editing rate was influenced by the method of the instructor’s introduction. Though block-editing did not affect working time and Lines of Code (LOC), it could reduce the compile error correction time, whereas using Java requires approximately 20% of compile error correction time for students. We concluded that block-based language worked to encourage students to focus high-level algorithm creation, as well as it provides an advantage to understanding text-based language.
Document type :
Conference papers
Complete list of metadatas
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-01625380
Contributor : Hal Ifip <>
Submitted on : Friday, October 27, 2017 - 3:05:55 PM
Last modification on : Monday, April 30, 2018 - 5:28:02 PM
Long-term archiving on : Sunday, January 28, 2018 - 3:34:48 PM
File
434862_1_En_2_Chapter.pdf
Identifiers
Citation
Yoshiaki Matsuzawa, Yoshiki Tanaka, Sanshiro Sakai. Measuring an Impact of Block-Based Language in Introductory Programming. 1st International Conference on Stakeholders and Information Technology in Education (SAITE), Jul 2016, Guimarães, Portugal. pp.16-25, ⟨10.1007/978-3-319-54687-2_2⟩. ⟨hal-01625380⟩
Share
Metrics
Record views
60
Files downloads
99
