Implementing an Integer Linear Approach to Multi-objective Phasor Measurement Unit Placement
Abstract : In this paper, an Integer Linear Programming (ILP) problem for a model of Multi-Objective Optimal PMU Placement (MOPP) is proposed. The proposed approach concurrently deals with two objectives. The first objective is the number of phasor measurement units (PMUs) which should be minimized. The second objective function is measurement redundancy which is the number of observable buses in the case of PMU outage. In fact, whatever the amount of second objective increases, the system would be more reliable. Furthermore, some linearized formulations are defined for each nonlinear formula. In fact, the nonlinear nature of formulation related to redundancy is substituted by linear inequality and so there is no nonlinear formula such that the calculation of the problem would be simplified. Finally, a modified 9-bus test system is implemented to show how the proposed method is effective.
Document type :
Conference papers
Complete list of metadatas
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-01629564
Contributor : Hal Ifip <>
Submitted on : Monday, November 6, 2017 - 3:28:43 PM
Last modification on : Monday, November 6, 2017 - 3:32:21 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2020-01-01
Please log in to resquest access to the document
Identifiers
Citation
Amir Baharvandi, Miadreza Shafie-Khah, Saber Talari, João Catalão. Implementing an Integer Linear Approach to Multi-objective Phasor Measurement Unit Placement. 8th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), May 2017, Costa de Caparica, Portugal. pp.297-304, ⟨10.1007/978-3-319-56077-9_29⟩. ⟨hal-01629564⟩
Share
Metrics
Record views
91
