Flexibilizing Distribution Network Systems via Dynamic Reconfiguration to Support Large-Scale Integration of Variable Energy Sources Using a Genetic Algorithm
Abstract : In recent years, the level of variable Renewable Energy Sources (vRESs) integrated in power systems has been increasing steadily. This is driven by a multitude of global and local concerns related to energy security and dependence, climate change, etc. The integration of such energy sources is expected to continue growing in the coming years. Despite their multifaceted benefits, variable energy sources introduce technical challenges mainly because of their intermittent nature, particularly at distribution levels. The flexibility of existing distribution systems should be significantly enhanced to partially reduce the side effects of vRESs. One way to do this is using a dynamic network reconfiguration. Framed in this context, this work presents an optimization problem to investigate the impacts of grid reconfiguration on the level of integration and utilization of vRES power in the system. The developed combinatorial model is solved using a genetic algorithm. A standard IEEE 33-node distribution system is employed in the analysis. Simulation results show the capability of network switching in supporting large-scale integration of vRESs in the system while alleviating their side effects. Moreover, the simultaneous consideration of vRES integration and network reconfiguration lead to a better voltage profile, reduced costs and losses in the system.
Document type :
Conference papers
Complete list of metadatas
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-01629578
Contributor : Hal Ifip <>
Submitted on : Monday, November 6, 2017 - 3:29:23 PM
Last modification on : Monday, November 6, 2017 - 3:32:13 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2020-01-01
Please log in to resquest access to the document
Identifiers
Citation
Marco Cruz, Desta Fitiwi, Sérgio Santos, João Catalão. Flexibilizing Distribution Network Systems via Dynamic Reconfiguration to Support Large-Scale Integration of Variable Energy Sources Using a Genetic Algorithm. 8th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), May 2017, Costa de Caparica, Portugal. pp.72-80, ⟨10.1007/978-3-319-56077-9_6⟩. ⟨hal-01629578⟩
Share
Metrics
Record views
103
