Conference papers
A Framework for Moving Target Defense Quantification
Abstract : Moving Target Defense (MTD) has emerged as a game changer in the security landscape, as it can create asymmetric uncertainty favoring the defender. Despite the significant work done in this area and the many different techniques that have been proposed, MTD has not yet gained widespread adoption due to several limitations. Specifically, interactions between multiple techniques have not been studied yet and a unified framework for quantifying and comparing very diverse techniques is still lacking. To overcome these limitations, we propose a framework to model how different MTD techniques can affect the information an attacker needs to exploit a system’s vulnerabilities, so as to introduce uncertainty and reduce the likelihood of successful attacks. We illustrate how this framework can be used to compare two sets of MTDs, and to select an optimal set of MTDs that maximize security within a given budget. Experimental results show that our approach is effective.
Document type :
Conference papers
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-01648997
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, November 27, 2017 - 10:31:21 AM
Last modification on : Monday, November 27, 2017 - 10:34:10 AM
File
449885_1_En_9_Chapter.pdf
Identifiers
Citation
Warren Connell, Massimiliano Albanese, Sridhar Venkatesan. A Framework for Moving Target Defense Quantification. 32th IFIP International Conference on ICT Systems Security and Privacy Protection (SEC), May 2017, Rome, Italy. pp.124-138, ⟨10.1007/978-3-319-58469-0_9⟩. ⟨hal-01648997⟩
Share
Metrics
Record views
210
Files downloads
138
