Abstract : To study the effect of calibration set on quantitatively determining test weight of maize by near-infrared spectroscopy, 584 maize samples were collected and scanned for near-infrared spectral data. Test weight was measured following the standard GB 1353-2009, resulting the sample test weight of 693–732 g•L−1. Two calibration models were respectively built using partial least squares regression, based on two different calibration sets. Test weight of two calibration sets distribute differently, with normal and homogeneous distributions. Both quantitative models were selected by root mean square error of cross validation (RMSECV), and evaluated by validation set. Results show the RMSECV of the model based on normal distribution calibration set is 4.28 g•L−1, the RMSECV of the model based on homogeneous distribution calibration set is 2.99 g•L−1, the predication of two models have significant difference for the samples with high or low test weight.
https://hal.inria.fr/hal-02179969
Contributor : Hal Ifip <>
Submitted on : Friday, July 12, 2019 - 9:04:15 AM Last modification on : Friday, July 12, 2019 - 9:05:56 AM
File
Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed
until : 2021-07-12
Lianping Jia, Peng Jiao, Junning Zhang, Zhen Zeng, Xunpeng Jiang. Effect of Calibration Set Selection on Quantitatively Determining Test Weight of Maize by Near-Infrared Spectroscopy. 10th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2016, Dongying, China. pp.481-488, ⟨10.1007/978-3-030-06155-5_49⟩. ⟨hal-02179969⟩
