Computer and Computing Technologies in Agriculture X 110th IFIP WG 5.14 International Conference, CCTA 2016 Dongying, China, October 19–21, 2016
Conference papers
Research on Variation Rule of Sensible Heat Flux in Field Under Different Soil Moisture Content and Underlying Surface by Large Aperture Scintillometer
Abstract : The surface sensible heat flux has a profound impact on regional energy balance of payments and regional water cycle, which is an important part of composition of the surface energy balance. This research was based on the large aperture scintillometer (LAS), combined with eddy covariance system. Sensible heat fluxes in field in September 2015 - April 2016 were observed continuously on Daxing district experimental base in Beijing. The original data was processed by BLS software and the data process cycle of large aperture scintillometer was established.The analysis of sensible heat fluxes in field under different soil moisture content and different underlying surface could provide theoretical basis for variability of sensible heat fluxes in field.
https://hal.inria.fr/hal-02179971
Contributor : Hal Ifip <>
Submitted on : Friday, July 12, 2019 - 9:20:07 AM Last modification on : Friday, July 12, 2019 - 9:20:39 AM
File
Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed
until : 2021-07-12
Xin Han, Qingyun Zhou, Baozhong Zhang, Di Xu. Research on Variation Rule of Sensible Heat Flux in Field Under Different Soil Moisture Content and Underlying Surface by Large Aperture Scintillometer. 10th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2016, Dongying, China. pp.310-317, ⟨10.1007/978-3-030-06155-5_31⟩. ⟨hal-02179971⟩
