Conference papers
Design Method for Chemical Clogging Emitters Boundary Optimization
Abstract : Fractal flow channel structure as research object, based on chemical clogging condition of the physical model. It was analyzed using computational fluid dynamics (CFD) simulation and reveals the fractal flow channel internal flow characteristics of water and sediment. Fractal flow channel non-energy dissipation of the arc angle design optimization. Using standard κ-ε turbulence model and the DPM model, calculated: (1) As for the hydraulic performance analysis, before optimization emitter flow exponent of 0.487, 0.489 after optimization; From the inner flow field analysis, When the pressure head from 5 m to 15 m, before optimization emitter maximum flow rate from 2.09 m/s to 3.70 m/s, the maximum flow rate to optimize the emitter from 2.15 m/s to 3.81 m/s, the maximum optimization of flow rates were increased compared to the previous 2.87%, 3.34%, 2.97%, the flow rate improved. After optimizing the eddy region, the velocity of the outer edge of the eddy region increased from (0.005–0.752 m/s) to (0.311–0.930 m/s), which improved the self-cleaning ability of the irrigator. Based on the analysis of blockage performance, the passing rate of particles is significantly improved after optimizing the flow channel. Considering the optimized emitter has excellent hydraulic performance and anti-clogging properties.
Document type :
Conference papers
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-02179983
Contributor : Hal Ifip <>
Submitted on : Friday, July 12, 2019 - 10:57:43 AM
Last modification on : Friday, July 12, 2019 - 10:58:57 AM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2021-07-12
Please log in to resquest access to the document
Identifiers
Citation
Xu Li, Peiling Yang, Shumei Ren, Lili Zhangzhong, Lihong Yang. Design Method for Chemical Clogging Emitters Boundary Optimization. 10th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2016, Dongying, China. pp.318-329, ⟨10.1007/978-3-030-06155-5_32⟩. ⟨hal-02179983⟩
Share
Metrics
Record views
174
