Conference papers
The Association Rules Algorithm Based on Clustering in Mining Research in Corn Yield
Abstract : With the popularization of agricultural information technology, the use of data mining techniques to analyze the impact of different types of soil nutrient content and yield of corn has become a hot topic in the field of agriculture. Association rule mining is an important part of the field in Data mining, association rules can be found associated with agricultural data attributes. This article will use cluster analysis and association rule to analysis correlation between corn yield and soil nutrient. Firstly compare different clustering algorithm to chooses the optimal algorithm, make data collected in scientific classification, and based on expert knowledge of the collected data into different levels; then determine the type and content of different soil by association rules corn yield and soil nutrient; final inspection algorithm is correct. The results showed that: comparing K-means, hierarchical clustering analysis, and PAM, K-means algorithm to determine the optimal clustering; K value can be determined at selected intervals. K is equal to 3, 4 or 6, clustering effect is good according to Sil value when K from 3 to 10. Based on the principle of association rules, clustering algorithm to select a K value associated with the combination of rule 6; After clustering algorithm of association rules, support and credibility and improve degree of accuracy is better than not clustering; by mining association rules after clustering, a great influence on the different levels of soil nutrients in corn yield. The results for the corn yield provides intelligent decision support data.
Document type :
Conference papers
Complete list of metadata
Cited literature [27 references]  Display  Hide  Download
https://hal.inria.fr/hal-02180003
Contributor : Hal Ifip <>
Submitted on : Friday, July 12, 2019 - 2:27:45 PM
Last modification on : Friday, July 12, 2019 - 2:28:47 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2021-07-12
Please log in to resquest access to the document
Identifiers
Citation
Bo Liu, Guifen Chen. The Association Rules Algorithm Based on Clustering in Mining Research in Corn Yield. 10th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2016, Dongying, China. pp.268-278, ⟨10.1007/978-3-030-06155-5_26⟩. ⟨hal-02180003⟩
Share
Metrics
Record views
134
