HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Detecting data manipulation attacks on the substation interlocking function using direct power feedback
Abstract : Any form of deliberate physical or cyber activity that attempts to undermine the control mechanisms that maintain the key goals of reliability, efficiency and safety of a physical system can be considered to be an attack on the system. Indeed, an attack can be as subtle as a configuration change that prevents the optimal operation of a power system.This chapter describes an approach that enhances the security of the interlocking function in a power distribution substation by using the power flow behavior of the physical system during switching events as direct power feedback. The approach detects potential over-the-network data modification attacks on the interlocking function using out-of-bounds sensor measurements. The direct power feedback adds an extra layer of security and redundancy to existing power substation interlocking function protection mechanisms.
Document type :
Conference papers
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-01819136
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Wednesday, June 20, 2018 - 9:23:52 AM
Last modification on : Wednesday, June 20, 2018 - 9:34:09 AM
Long-term archiving on: : Tuesday, September 25, 2018 - 11:22:38 AM
File
460140_1_En_3_Chapter.pdf
Identifiers
Citation
Eniye Tebekaemi, Edward Colbert, Duminda Wijesekera. Detecting data manipulation attacks on the substation interlocking function using direct power feedback. 11th International Conference on Critical Infrastructure Protection (ICCIP), Mar 2017, Arlington, VA, United States. pp.45-62, ⟨10.1007/978-3-319-70395-4_3⟩. ⟨hal-01819136⟩
Share
Metrics
Record views
44
Files downloads
133
