Conference papers
System-Oriented Reliability-Based Methodology for Optimal Joint Maintenance and Production Planning
Abstract : The integration among the organizational functions managing assets along its lifecycle is a crucial aspect for production companies to implement Asset Management. In this paper, an iterative four-step methodology is presented to support the joint maintenance and production planning considering the system configuration optimization as well. The objective is to overcome the limitations of most of the approaches that can be found in the literature regarding joint optimization models, by integrating it with a system-oriented and reliability-based approach. Reliability, Maintainability and Availability analysis at system level is used to support the traditional joint optimization models. The methodology is applied in an industrial case in the mining sector.
Document type :
Conference papers
Complete list of metadata
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01666159
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, December 18, 2017 - 10:38:02 AM
Last modification on : Tuesday, August 13, 2019 - 11:10:03 AM
File
456370_1_En_11_Chapter.pdf
Identifiers
Citation
I. Roda, M. Macchi, C. Parmigiani, A. Arata. System-Oriented Reliability-Based Methodology for Optimal Joint Maintenance and Production Planning. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2017, Hamburg, Germany. pp.92-100, ⟨10.1007/978-3-319-66923-6_11⟩. ⟨hal-01666159⟩
Share
Metrics
Les métriques sont temporairement indisponibles
