Artificial Intelligence for Knowledge Management 4th IFIP WG 12.6 International Workshop, AI4KM 2016 Held at IJCAI 2016 New York, NY, USA, July 9, 2016
Conference papers
Conceptual Navigation for Polyadic Formal Concept Analysis
Abstract : Formal Concept Analysis (FCA) is a mathematically inspired field of knowledge representation with wide applications in knowledge discovery and decision support. Polyadic FCA is a generalization of classical FCA that instead of a binary uses an arbitrary, n-ary incidence relation to define formal concepts, i.e., data clusters in which all elements are interrelated. We discuss a paradigm for navigating the space of such (formal) concepts, based on so-called membership constraints. We present an implementation for the cases $$n\in \{2,3,4\}$$ using an encoding into answer-set programming (ASP) allowing us to exploit highly efficient strategies offered by optimized ASP solvers. For the case $$n=3$$, we compare this implementation to a second strategy that uses exhaustive search in the concept set, which is precomputed by an existing tool. We evaluate the implementation strategies in terms of performance. Finally, we discuss the limitations of each approach and the possibility of generalizations to n-ary datasets.
https://hal.inria.fr/hal-01950006 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, December 10, 2018 - 3:09:27 PM Last modification on : Thursday, January 7, 2021 - 2:30:03 PM Long-term archiving on: : Monday, March 11, 2019 - 3:13:40 PM
Sebastian Rudolph, Christian Săcărea, Diana Troancă. Conceptual Navigation for Polyadic Formal Concept Analysis. 4th IFIP International Workshop on Artificial Intelligence for Knowledge Management (AI4KM), Jul 2016, New York, NY, United States. pp.50-70, ⟨10.1007/978-3-319-92928-6_4⟩. ⟨hal-01950006⟩
