Conference papers
A Visual Quality Index for Fuzzy C-Means
Abstract : Cluster analysis is widely used in the areas of machine learning and data mining. Fuzzy clustering is a particular method that considers that a data point can belong to more than one cluster. Fuzzy clustering helps obtain flexible clusters, as needed in such applications as text categorization. The performance of a clustering algorithm critically depends on the number of clusters, and estimating the optimal number of clusters is a challenging task. Quality indices help estimate the optimal number of clusters. However, there is no quality index that can obtain an accurate number of clusters for different datasets. Thence, in this paper, we propose a new cluster quality index associated with a visual, graph-based solution that helps choose the optimal number of clusters in fuzzy partitions. Moreover, we validate our theoretical results through extensive comparison experiments against state-of-the-art quality indices on a variety of numerical real-world and artificial datasets.
Document type :
Conference papers
Complete list of metadatas
Cited literature [17 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-01727426
Contributor : Jérôme Darmont <>
Submitted on : Wednesday, May 30, 2018 - 8:29:19 AM
Last modification on : Thursday, April 30, 2020 - 10:12:02 AM
Long-term archiving on: : Friday, August 31, 2018 - 2:44:11 PM
A Visual Quality Index for Fuz...
Identifiers
Citation
Aybükë Oztürk, Stéphane Lallich, Jérôme Darmont. A Visual Quality Index for Fuzzy C-Means. 14th International Conference on Artificial Intelligence Applications and Innovations (AIAI 2018), May 2018, Rhodes, Greece. pp.546-555, ⟨10.1007/978-3-319-92007-8_46⟩. ⟨hal-01727426⟩
Share
Metrics
Record views
534
Files downloads
430
