Full Text Documents
24
Search
Table of Contents
Artificial Intelligence Applications and Innovations
Lazaros Iliadis, Ilias Maglogiannis, Vassilis Plagianakos
Front Matter
SEDSEAL
Semantic Models for Labeling Spectrum Data
Vaishali Nagpure, Cynthia Hood, Stephanie Vaccaro
3-12
Towards Big Data Analytics in Large-Scale Federations of Semantically Heterogeneous IoT Platforms
Ilias Kalamaras, Nikolaos Kaklanis, Kostantinos Votis, Dimitrios Tzovaras
13-23
5G-PINE
On Edge Cloud Architecture and Joint Physical Virtual Resource Orchestration for SDN/NFV
Shah Khan, Roberto Riggio
27-38
Use Cases for 5G Networks Using Small Cells
Alexandros Kostopoulos, Ioannis Chochliouros, Daniele Munaretto, Claudio Meani, Claus Keuker, Elisenda Garriga, Javier Hidalgo, Miguel Cid, Hicham Khalifé, Fidel Liberal
39-49
Enhancing Network Management via NFV, MEC, Cloud Computing and Cognitive Features: The “5G ESSENCE” Modern Architectural Approach
Ioannis Chochliouros, Anastasia Spiliopoulou, Anastasios Kourtis, Ioannis Giannoulakis, Michail-Alexandros Kourtis, Emmanouil Kafetzakis, Eirini Vasilaki, Marinos Agapiou, Mike Iosifidis
50-61
e-Health Services in the Context of IoT: The Case of the VICINITY Project
Maria Belesioti, Ioannis Chochliouros, Stefan Vanya, Viktor Oravec, Natalia Theologou, Maria Koutli, Athanasios Tryferidis, Dimitrios Tzovaras
62-69
Are 5G Networks and the Neutral Host Model the Solution to the Shrinking Telecom Market
Ioannis Neokosmidis, Theodoros Rokkas, Dimitris Xydias, Antonino Albanese, Muhammad Siddiqui, Carlos Colman-Meixner, Dimitra Simeonidou
70-77
An Experimental Assessment of Channel Selection in Cognitive Radio Networks
Anna Umbert, Oriol Sallent, Jordi Perez-Romero, Juan Sánchez-González, Diarmuid Collins, Maicon Kist
78-88
Space/Time Traffic Fluctuations in a Cellular Network: Measurements’ Analysis and Potential Applications
Juan Sánchez-González, Oriol Sallent, Jordi Perez-Romero
89-98
MHDW
Detecting Question Intention Using a K-Nearest Neighbor Based Approach
Alaa Mohasseb, Mohamed Bader-El-Den, Mihaela Cocea
101-111
Incremental Learning for Large Scale Classification Systems
Athanasios Alexopoulos, Andreas Kanavos, Konstantinos Giotopoulos, Alaa Mohasseb, Mohamed Bader-El-Den, Athanasios Tsakalidis
112-122
Argumentative Discourse Concepts as Revealed by Traversing a Graph
Panagiotis Gourgaris, Andreas Kanavos, Nikos Karacapilidis, Vassilis Tampakas
123-132
Query Disambiguation Based on Clustering Techniques
Panagiota Kotoula, Christos Makris
133-145
Automatic Selection of Parallel Data for Machine Translation
Despoina Mouratidis, Katia Kermanidis
146-156
The Biomolecular Computation Paradigm: A Survey in Massive Biological Computation
Georgios Drakopoulos, Dimitrios Tsolis, Antonia Stefani, Phivos Mylonas
157-167
How Much Different Are Two Words with Different Shortest Periods
Mai Alzamel, Maxime Crochemore, Costas Iliopoulos, Tomasz Kociumaka, Ritu Kundu, Jakub Radoszewski, Wojciech Rytter, Tomasz Waleń
168-178
Non-coding RNA Sequences Identification and Classification Using a Multi-class and Multi-label Ensemble Technique
Michalis Stavridis, Aigli Korfiati, Georgios Sakellaropoulos, Seferina Mavroudi, Konstantinos Theofilatos
179-188
A Multi-metric Algorithm for Hierarchical Clustering of Same-Length Protein Sequences
Sotirios–filippos Tsarouchis, Maria Kotouza, Fotis Psomopoulos, Pericles Mitkas
189-199
Towards String Sanitization
Oluwole Ajala, Hayam Alamro, Costas Iliopoulos, Grigorios Loukides
200-210
Efficient Recognition of Abelian Palindromic Factors and Associated Results
Costas Iliopoulos, Steven Watts
211-223
HEALTHIOT
Recommender Systems for IoT Enabled m-Health Applications
Seda Erdeniz, Ilias Maglogiannis, Andreas Menychtas, Alexander Felfernig, Thi Tran
227-237
A Smart-Home IoT Infrastructure for the Support of Independent Living of Older Adults
Stefanos Stavrotheodoros, Nikolaos Kaklanis, Konstantinos Votis, Dimitrios Tzovaras
238-249
A Generic Approach for Capturing Reliability in Medical Cyber-Physical Systems
Argyro Mavrogiorgou, Athanasios Kiourtis, Dimosthenis Kyriazis
250-262
Advancing Quantified-Self Applications Utilizing Visual Data Analytics and the Internet of Things
Dimitris Chousiadas, Andreas Menychtas, Panayiotis Tsanakas, Ilias Maglogiannis
263-274
Designed by Inria-IES Team : http://hal.inria.fr/    Hosted by HAL : http://hal.archives-ouvertes.fr/
