Enhancement of IoT Applications Dependability Using Bayesian Networks
Abstract : Sensors play a vital role in Internet of Things (IoT) monitoring applications. However, the harsh nature of the environment influences negatively on the sensors reliability. They may occasionally generate inaccurate measurements when they are exposed to high level of humidity, temperature, etc. Forwarding incorrect data to the base station may cause disastrous decision-making in critical applications. To address this problem, we proposed a new fault-tolerant mechanism based on Bayesian Networks that carefully solve such a problem. The mechanism is called Reliability of Captured Data (RCD); it enables sensors to both detect and recover faulty data. To show the performance of our algorithm, we compared this latter with another recent algorithm called Fault Detection Scheme (FDS) using Network Simulator 2 (NS2). The results showed that our strategy gives remarkable enhancements in terms of fault detection accuracy and fault alarm rate.
Document type :
Conference papers
Liste complète des métadonnées
https://hal.inria.fr/hal-01913875
Contributor : Hal Ifip <>
Submitted on : Tuesday, November 6, 2018 - 4:58:58 PM
Last modification on : Thursday, November 8, 2018 - 1:51:30 PM
Document(s) archivé(s) le : Thursday, February 7, 2019 - 4:03:29 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2021-01-01
Please log in to resquest access to the document
Identifiers
Citation
Yasmine Harbi, Zibouda Aliouat, Sarra Hammoudi. Enhancement of IoT Applications Dependability Using Bayesian Networks. 6th IFIP International Conference on Computational Intelligence and Its Applications (CIIA), May 2018, Oran, Algeria. pp.487-497, ⟨10.1007/978-3-319-89743-1_42⟩. ⟨hal-01913875⟩
Share
Metrics
Record views
11
