Conjugate Gradient Method for Brain Magnetic Resonance Images Segmentation
Abstract : Image segmentation is the process of partitioning the image into regions of interest in order to provide a meaningful representation of information. Nowadays, segmentation has become a necessity in many practical medical imaging methods as locating tumors and diseases. Hidden Markov Random Field model is one of several techniques used in image segmentation. It provides an elegant way to model the segmentation process. This modeling leads to the minimization of an objective function. Conjugate Gradient algorithm (CG) is one of the best known optimization techniques. This paper proposes the use of the nonlinear Conjugate Gradient algorithm (CG) for image segmentation, in combination with the Hidden Markov Random Field modelization. Since derivatives are not available for this expression, finite differences are used in the CG algorithm to approximate the first derivative. The approach is evaluated using a number of publicly available images, where ground truth is known. The Dice Coefficient is used as an objective criterion to measure the quality of segmentation. The results show that the proposed CG approach compares favorably with other variants of Hidden Markov Random Field segmentation algorithms.
Document type :
Conference papers
Complete list of metadatas
Cited literature [44 references]  Display  Hide  Download
https://hal.inria.fr/hal-01913885
Contributor : Hal Ifip <>
Submitted on : Tuesday, November 6, 2018 - 5:18:32 PM
Last modification on : Friday, December 7, 2018 - 4:48:04 PM
Long-term archiving on : Thursday, February 7, 2019 - 4:37:56 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2021-01-01
Please log in to resquest access to the document
Identifiers
Citation
El-Hachemi Guerrout, Samy Ait-Aoudia, Dominique Michelucci, Ramdane Mahiou. Conjugate Gradient Method for Brain Magnetic Resonance Images Segmentation. 6th IFIP International Conference on Computational Intelligence and Its Applications (CIIA), May 2018, Oran, Algeria. pp.561-572, ⟨10.1007/978-3-319-89743-1_48⟩. ⟨hal-01913885⟩
Share
Metrics
Record views
89
