Conference papers
An Efficient Cooperative Method to Solve Multiple Sequence Alignment Problem
Abstract : In this research work, we propose a cooperative approach called simulated particle swarm optimization (SPSO) which is based on metaheuristics to find an approximate solution for the multiple sequence alignment (MSA) problem. The developed approach uses the particle swam optimization (PSO) algorithm to discover the search space globally and the simulated annealing (SA) technique to improve the population leader «gbest» quality in order to overcome local optimum problem. Simulation results on BaliBASE benchmarks have shown the potent of the proposed method to produce good quality alignments comparing to those given by other existing methods.
Complete list of metadatas
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/hal-01913906
Contributor : Hal Ifip <>
Submitted on : Wednesday, November 7, 2018 - 10:36:24 AM
Last modification on : Thursday, November 8, 2018 - 1:19:13 PM
Document(s) archivé(s) le : Friday, February 8, 2019 - 1:17:19 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2021-01-01
Please log in to resquest access to the document
Identifiers
Citation
Lamiche Chaabane. An Efficient Cooperative Method to Solve Multiple Sequence Alignment Problem. 6th IFIP International Conference on Computational Intelligence and Its Applications (CIIA), May 2018, Oran, Algeria. pp.185-195, ⟨10.1007/978-3-319-89743-1_17⟩. ⟨hal-01913906⟩
Share
Metrics
Record views
53
