A Parallel Implementation of GHB Tree
Abstract : Searching in a dataset remains a fundamental problem for many applications. The general purpose of many similarity measures is to focus the search on as few elements as possible to find the answer. The current indexing techniques divides the target dataset into subsets. However, in large amounts of data, the volume of these regions explodes, which will affect search algorithms. The research tends to degenerate into a complete analysis of the data set. In this paper, we proposed a new indexing technique called GHB-tree. The first idea, is to limit the volume of the space. The goal is to eliminate some objects without the need to compute their relative distances to a query object. Peer-to-peer networks (P2P) are superimposed networks that connect independent computers (also known as nodes or peers). GHB-tree has been optimized for secondary memory in peer-to-peer networks. We proposed a parallel search algorithm on a set of real machine. We also discussed the effectiveness of construction and search algorithms, as well as the quality of the index.
Document type :
Conference papers
Abdelmalek Amine; Malek Mouhoub; Otmane Ait Mohamed; Bachir Djebbar. 6th IFIP International Conference on Computational Intelligence and Its Applications (CIIA), May 2018, Oran, Algeria. Springer International Publishing, IFIP Advances in Information and Communication Technology, AICT-522, pp.47-55, 2018, Computational Intelligence and Its Applications. 〈10.1007/978-3-319-89743-1_5〉
Liste complète des métadonnées
https://hal.inria.fr/hal-01913954
Contributor : Hal Ifip <>
Submitted on : Wednesday, November 7, 2018 - 10:50:40 AM
Last modification on : Thursday, November 8, 2018 - 1:04:13 PM
Document(s) archivé(s) le : Friday, February 8, 2019 - 1:59:21 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2021-01-01
Please log in to resquest access to the document
Identifiers
Citation
Zineddine Kouahla, Adeel Anjum. A Parallel Implementation of GHB Tree. Abdelmalek Amine; Malek Mouhoub; Otmane Ait Mohamed; Bachir Djebbar. 6th IFIP International Conference on Computational Intelligence and Its Applications (CIIA), May 2018, Oran, Algeria. Springer International Publishing, IFIP Advances in Information and Communication Technology, AICT-522, pp.47-55, 2018, Computational Intelligence and Its Applications. 〈10.1007/978-3-319-89743-1_5〉. 〈hal-01913954〉
Share
Metrics
Record views
9
