Conference papers
A Detail Preserving Vector Median Filter Based on Texture Analysis
Abstract : A texture detail preserving vector filter is proposed to remove impulsive noise in color images. By computing the texture complexity of the local neighborhood centered at each pixel according to the texture analysis of the color image, the proposed method classifies the local neighborhood into smooth region or texture one. For smooth regions and texture regions, different smoothing strategies are performed. For a smooth region, more smoothing is needed, whereas for a texture region the amount of smoothing should be controlled by its texture complexity. Experimental results show that the proposed method obviously outperforms the classical VMF both in noise suppression and in texture and detail preservation.
Document type :
Conference papers
Complete list of metadatas
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/hal-02197776
Contributor : Hal Ifip <>
Submitted on : Tuesday, July 30, 2019 - 5:00:58 PM
Last modification on : Tuesday, July 30, 2019 - 5:12:24 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2021-01-01
Please log in to resquest access to the document
Identifiers
Citation
Ying Pan, Shihui Wang. A Detail Preserving Vector Median Filter Based on Texture Analysis. 10th International Conference on Intelligent Information Processing (IIP), Oct 2018, Nanning, China. pp.204-209, ⟨10.1007/978-3-030-00828-4_21⟩. ⟨hal-02197776⟩
Share
Metrics
Record views
85
