index - VLSI-SoC: Design and Engineering of Electronics Systems Based on New Computing Paradigms Access content directly
Full Text Documents
Chargement de la page
Search
Table of Contents
Nicola Bombieri, Graziano Pravadelli, Masahiro Fujita, Todd Austin, Ricardo Reis
Front Matter
A 65 nm CMOS Synthesizable Digital Low-Dropout Regulator Based on Voltage-to-Time Conversion with 99.6% Current Efficiency at 10-mA Load
Naoki Ojima, Toru Nakura, Tetsuya Iizuka, Kunihiro Asada
1-13
An Instruction Set Architecture for Secure, Low-Power, Dynamic IoT Communication
Shahzad Muzaffar, Ibrahim Elfadel
14-31
The Connection Layout in a Lattice of Four-Terminal Switches
Anna Bernasconi, Antonio Boffa, Fabrizio Luccio, Linda Pagli
32-52
Building High-Performance, Easy-to-Use Polymorphic Parallel Memories with HLS
L. Stornaiuolo, M. Rabozzi, M. Santambrogio, D. Sciuto, C. Ciobanu, G. Stramondo, A. Varbanescu
53-78
Rectification of Arithmetic Circuits with Craig Interpolants in Finite Fields
Utkarsh Gupta, Irina Ilioaea, Vikas Rao, Arpitha Srinath, Priyank Kalla, Florian Enescu
79-106
Energy-Accuracy Scalable Deep Convolutional Neural Networks: A Pareto Analysis
Valentino Peluso, Andrea Calimera
107-127
ReRAM Based In-Memory Computation of Single Bit Error Correcting BCH Code
Yaswanth Tavva, Debjyoti Bhattacharjee, Anupam Chattopadhyay, Swagata Mandal
128-146
Optimizing Performance and Energy Overheads Due to Fanout in In-Memory Computing Systems
Md Zaman, Rajeev Joshi, Srinivas Katkoori
147-166
Mapping Spiking Neural Networks on Multi-core Neuromorphic Platforms: Problem Formulation and Performance Analysis
Francesco Barchi, Gianvito Urgese, Enrico Macii, Andrea Acquaviva
167-186
Improved Test Solutions for COTS-Based Systems in Space Applications
Riccardo Cantoro, Sara Carbonara, Andrea Florida, Ernesto Sanchez, Matteo Sonza Reorda, Jan-Gerd Mess
187-206
Analysis of Bridge Defects in STT-MRAM Cells Under Process Variations and a Robust DFT Technique for Their Detection
Victor Champac, Andres Gomez, Freddy Forero, Kaushik Roy
207-231
Assessment of Low-Budget Targeted Cyberattacks Against Power Systems
Xiaorui Liu, Anastasis Keliris, Charalambos Konstantinou, Marios Sazos, Michail Maniatakos
232-256
Efficient Hardware/Software Co-design for NTRU
Tim Fritzmann, Thomas Schamberger, Christoph Frisch, Konstantin Braun, Georg Maringer, Martha Johanna Sepulveda Florez
257-280
