Conference papers
Decision Support System for Joint Product Design and Reconfiguration of Production Systems
Abstract : Reconfigurable manufacturing systems (RMS) are designed to be able to be reconfigured to produce new items. Nevertheless, reconfigurations of a RMS may be time consuming and costly if they are not considered since early steps of new item design. This work describes a decision support system to auto-matically generate and test configurations for such RMSs based on a computer-aided design (CAD) model of a new product. The proposed methodology consists of two main steps. First, a matrix of possible assembly plans (taking into account resource/tool compatibility, geometric constraints, …) is generated with a skill-based comparison between the new item and the production resources. Second, the assembly plan with minimum reconfiguration cost is found through mathe-matical optimization. The solution is analyzed by a simulation model in the end. Experiments performed on small use case validate the proposed methodology.
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal-imt-atlantique.archives-ouvertes.fr/hal-02355032
Contributor : Simon Thevenin <>
Submitted on : Friday, January 24, 2020 - 4:02:01 PM
Last modification on : Tuesday, September 21, 2021 - 4:06:16 PM
Long-term archiving on: : Saturday, April 25, 2020 - 4:13:39 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2022-01-01
Please log in to resquest access to the document
Identifiers
Citation
S. Ehsan Hashemi-Petroodi, Clemens Gonnermann, Magdalena Paul, Simon Thevenin, Alexandre Dolgui, et al.. Decision Support System for Joint Product Design and Reconfiguration of Production Systems. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.231-238, ⟨10.1007/978-3-030-30000-5⟩. ⟨hal-02355032⟩
Share
Metrics
Record views
471
