index - Wired/Wireless Internet Communications Access content directly
Full Text Documents
Chargement de la page
Search
Table of Contents
Yevgeni Koucheryavy, Lefteris Mamatas, Ibrahim Matta, Aleksandr Ometov, Panagiotis Papadimitriou
Front Matter
Network Analysis and Dimensioning
Bargaining over Fair Channel Sharing Between Wi-Fi and LTE-U Networks
Andrey Garnaev, Shweta Sagari, Wade Trappe
3-15
Time-Dependent SIR Analysis in Shopping Malls Using Fractal-Based Mobility Models
Yuri Orlov, Elisabeth Kirina-Lilinskaya, Andrey Samuylov, Aleksandr Ometov, Dmitri Moltchanov, Yulia Gaimamaka, Sergey Andreev, Konstantin Samouylov
16-25
Analysis and Performance Evaluation of SDN Queue Model
Samuel Muhizi, Gregory Shamshin, Ammar Muthanna, Ruslan Kirichek, Andrei Vladyko, Andrey Koucheryavy
26-37
Analysis of a Retrial Queue with Limited Processor Sharing Operating in the Random Environment
Sergey Dudin, Alexander Dudin, Olga Dudina, Konstantin Samouylov
38-49
Stationary Distribution of Waiting Time in MAP/G/1/N Queueing System with LIFO Service Discipline
Alexander Dudin, Valentina Klimenok, Konstantin Samouylov
50-61
5G Communications
Distributed Sleep Mode Power Control in 5G Ultra Dense Networks
Christos Bouras, Georgios Diles
65-76
System Model for Multi-level Cloud Based Tactile Internet System
Abdelhamied Ateya, Anastasia Vybornova, Konstantin Samouylov, Andrey Koucheryavy
77-86
Task Scheduling Scheme Based on Cost Optimization in 5G/Hetnets C-RAN
Olfa Chabbouh, Nazim Agoulmine, Sonia Rejeb, Zièd Choukair
87-98
Energy Efficiency Performance for 5G Cellular Networks
Afef Bohli, Ridha Bouallegue
99-111
Network Design and Planning
Interaction of the IoT Traffic Generated by a Smart City Segment with SDN Core Network
Artem Volkov, Abdukodir Khakimov, Ammar Muthanna, Ruslan Kirichek, Andrei Vladyko, Andrey Koucheryavy
115-126
Evaluation of Geocast Routing Trees on Random and Actual Networks
Bernd Meijerink, Mitra Baratchi, Geert Heijenk
127-142
A NURBS Based Technique for an Optimized Transmit Opportunity Map Processing in WLAN Networks
Mehdi Guessous, Lahbib Zenkouar
143-154
Network Protocols
Load-Balancing Adaptive Clustering Refinement Algorithm for Wireless Sensor Network Clusters
Gal Oren, Leonid Barenboim, Harel Levin
157-173
Simulation and Testing of a Platooning Management Protocol Implementation
Bruno Ribeiro, Fábio Gonçalves, Alexandre Santos, Maria Nicolau, Bruno Dias, Joaquim Macedo, António Costa
174-185
Research of Interaction Between Applications of Augmented Reality and Control Methods of UAVs
Maria Makolkina, Ruslan Kirichek, Valeria Teltevskaya, Elisaveta Surodeeva
186-193
Energy-Efficient Power Control and Clustering in Underlay Device to Multi-device Communications
Mariem Hmila, Manuel Fernández-Veiga
194-206
Adaptive-Segmentation and Flexible-Delay Based Broadcasting Protocol for VANETs
Houda Hafi, Wahabou Abdou, Salah Merniz
207-218
Information Technology
NetFlow Anomaly Detection Though Parallel Cluster Density Analysis in Continuous Time-Series
Kieran Flanagan, Enda Fallon, Paul Connolly, Abir Awad
221-232
Investigation of Traffic Pattern for the Augmented Reality Applications
Maria Makolkina, Andrey Koucheryavy, Alexander Paramonov
233-246
Benefits of Multiply-Cascaded TCP Tunnel with Network Coding over Lossy Networks
Nguyen Ha, Kazumi Kumazoe, Kazuya Tsukamoto, Masato Tsuru
247-258
Circuit Design
A Broadband Power Amplifier Applied in GSM/TD-SCDMA/WLAN System
Wenyuan Li, Yan Ding, Hui Luo
261-270
IBIS-AMI Based PAM4 Signaling and FEC Technique for 25 Gb/s Serial Link
Yongzheng Zhan, Qingsheng Hu, Yinhang Zhang
271-281
Spur-Free MASH DDSM with Eliminable Dither
Yilong Liao, Xiangning Fan
282-291
A 20 Gb/s Wireline Receiver with Adaptive CTLE and Half-Rate DFE in 0.13 µm Technology
Yinhang Zhang, Qingsheng Hu, Yongzheng Zhan
292-303
Spur-Free and Stable Digital Delta-Sigma Modulator via Using HK-EFM
Xiangning Fan, Pengpeng Shi, Yilong Liao, Jian Tao
304-314
Compression Method to Remove Unnecessary MSBs of IQ Data Frames in C-RAN
Hojun Kwak, Sungkwon Park, Joonyoung Jung, Eunhui Hyun, Jewon Lee
315-322
Designed by Inria-IES Team : http://hal.inria.fr/    Hosted by HAL : http://hal.archives-ouvertes.fr/
