Formal Techniques for Distributed Objects, Components, and Systems 39th IFIP WG 6.1 International Conference, FORTE 2019 Held as Part of the 14th International Federated Conference on Distributed Computing Techniques, DisCoTec 2019 Kongens Lyngby, Denmark, June 17–21, 2019
Abstract : We introduce a new class of Parametric Timed Automata (PTAs) where we allow clocks to be compared to parameters in guards, as in classic PTAs, but also to be updated to parameters. We focus here on the EF-emptiness problem: "is the set of parameter valuations for which some given location is reachable in the instantiated timed automaton empty?". This problem is well-known to be undecidable for PTAs, and so it is for our extension. Nonetheless, if we update all clocks each time we compare a clock with a parameter and each time we update a clock to a parameter, we obtain a syntactic subclass for which we can decide the EF-emptiness problem and even perform the exact synthesis of the set of rational valuations such that a given location is reachable. To the best of our knowledge, this is the first non-trivial subclass of PTAs, actually even extended with parametric updates, for which this is possible.
https://hal.archives-ouvertes.fr/hal-02153238
Contributor : Étienne André <>
Submitted on : Friday, October 11, 2019 - 3:23:09 PM Last modification on : Tuesday, January 5, 2021 - 4:26:08 PM
File
Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed
until : 2021-10-11
Étienne André, Didier Lime, Mathias Ramparison. Parametric updates in parametric timed automata. 39th International Conference on Formal Techniques for Distributed Objects, Components, and Systems (FORTE), Jun 2019, Copenhagen, Denmark. pp.39-56, ⟨10.1007/978-3-030-21759-4_3⟩. ⟨hal-02153238⟩
