Conference papers
Learning a Behavior Model of Hybrid Systems Through Combining Model-Based Testing and Machine Learning
Abstract : Models play an essential role in the design process of cyber-physical systems. They form the basis for simulation and analysis and help in identifying design problems as early as possible. However, the construction of models that comprise physical and digital behavior is challenging. Therefore, there is considerable interest in learning such hybrid behavior by means of machine learning which requires sufficient and representative training data covering the behavior of the physical system adequately. In this work, we exploit a combination of automata learning and model-based testing to generate sufficient training data fully automatically.Experimental results on a platooning scenario show that recurrent neural networks learned with this data achieved significantly better results compared to models learned from randomly generated data. In particular, the classification error for crash detection is reduced by a factor of five and a similar F1-score is obtained with up to three orders of magnitude fewer training samples.
Complete list of metadata
Cited literature [39 references]  Display  Hide  Download
https://hal.inria.fr/hal-02526358
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, March 31, 2020 - 3:14:31 PM
Last modification on : Tuesday, March 31, 2020 - 3:41:47 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2022-01-01
Please log in to resquest access to the document
Identifiers
Citation
Bernhard Aichernig, Roderick Bloem, Masoud Ebrahimi, Martin Horn, Franz Pernkopf, et al.. Learning a Behavior Model of Hybrid Systems Through Combining Model-Based Testing and Machine Learning. 31th IFIP International Conference on Testing Software and Systems (ICTSS), Oct 2019, Paris, France. pp.3-21, ⟨10.1007/978-3-030-31280-0_1⟩. ⟨hal-02526358⟩
Share
Metrics
Record views
208
