Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Full Text Documents
Chargement de la page
Search
Table of Contents
Topics in Theoretical Computer Science
Luis Barbosa, Mohammad Ali Abam
Front Matter
Dirac-Based Reduction Techniques for Quantitative Analysis of Discrete-Time Markov Models
Mohammadsadegh Mohagheghi, Behrang Chaboki
1-16
Combining Machine and Automata Learning for Network Traffic Classification
Zeynab Sabahi-Kaviani, Fatemeh Ghassemi, Zahra Alimadadi
17-31
On the Complexity of the Upper r-Tolerant Edge Cover Problem
Ararat Harutyunyan, Mehdi Ghadikolaei, Nikolaos Melissinos, Jérôme Monnot, Aris Pagourtzis
32-47
Margin-Based Semi-supervised Learning Using Apollonius Circle
Mona Emadi, Jafar Tanha
48-60
Computing Boundary Cycle of a Pseudo-Triangle Polygon from Its Visibility Graph
Hossein Boomari, Soheila Farokhi
61-71
Improved Algorithms for Distributed Balanced Clustering
Kian Mirjalali, Hamid Zarrabi-Zadeh
72-84
Finite Interval-Time Transition System for Real-Time Actors
Shaghayegh Tavassoli, Ramtin Khosravi, Ehsan Khamespanah
85-100
Path Planning with Objectives Minimum Length and Maximum Clearance
Mansoor Davoodi, Arman Rouhani, Maryam Sanisales
101-115
Designed by Inria-IES Team : http://hal.inria.fr/    Hosted by HAL : http://hal.archives-ouvertes.fr/
