Conference papers
A Scalable Wireless Routing Protocol Secure against Route Truncation Attacks
Abstract : Wireless routing protocols allow transmitting nodes to have some knowledge of the topology in order to decide when to forward a packet (via broadcast) and when to drop it. Since a routing protocol forms the backbone of any network, it is a lucrative target for attacks. Routing protocols for wired networks (such as S-BGP) are not scalable in an ad-hoc wireless environment because of two main drawbacks: (1) the need to maintain knowledge about all immediate neighbors (which requires a discovery protocol), and (2) the need to transmit the same update several times, one for each neighbor. Although information about neighbors is readily available in a fairly static and wired network, such information is often not updated or available in an ad-hoc wireless network with mobile devices. Consequently, S-BGP is not suitable for such scenarios. We propose a BGP-type wireless routing protocol for such networks that does not suffer from such drawbacks. The protocol uses a novel authentication primitive called Enhanced Chain Signatures (ECS).
Document type :
Conference papers
Complete list of metadata
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01056372
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, August 18, 2014 - 6:13:20 PM
Last modification on : Friday, August 11, 2017 - 3:29:19 PM
Long-term archiving on: : Thursday, November 27, 2014 - 5:32:31 AM
File
CMS2010_final.pdf
Identifiers
Citation
Amitabh Saxena, Ben Soh. A Scalable Wireless Routing Protocol Secure against Route Truncation Attacks. 11th IFIP TC 6/TC 11 International Conference on Communications and Multimedia Security (CMS), May 2010, Linz, Austria. pp.4-15, ⟨10.1007/978-3-642-13241-4_2⟩. ⟨hal-01056372⟩
Share
Metrics
Record views
396
Files downloads
306
