Conference papers
Handwriting Biometric Hash Attack: A Genetic Algorithm with User Interaction for Raw Data Reconstruction
Abstract : Biometric Hash algorithms, also called BioHash, are mainly designed to ensure template protection to its biometric raw data. To assure reproducibility, BioHash algorithms provide a certain level of robustness against input variability to ensure high reproduction rates by compensating for intra-class variation of the biometric raw data. This concept can be a potential vulnerability. In this paper, we want to reflect such vulnerability of a specific Biometric Hash algorithm for handwriting, which was introduced in [1], consider and discuss possible attempts to exploit these flaws. We introduce a new reconstruction approach, which exploits this vulnerability; to generate artificial raw data out of a reference BioHash. Motivated by work from Cappelli et al. for fingerprint modality in [6] further studied in [3], where such an artificially generated raw data has the property of producing false positive recognitions, although they may not necessarily be visually similar. Our new approach for handwriting is based on genetic algorithms combined with user interaction in using a design vulnerability of the BioHash with an attack corresponding to cipher-text-only attack with side information as system parameters from BioHash. To show the general validity of our concept, in first experiments we evaluate using 60 raw data sets (5 individuals overall) consisting of two different handwritten semantics (arbitrary Symbol and fixed PIN). Experimental results demonstrate that reconstructed raw data produces an EERreconstr. in the range from 30% to 75%, as compared to non-attacked inter-class EERinter-class of 5% to 10% and handwritten PIN semantic can be better reconstructed than the Symbol semantic using this new technique. The security flaws of the Biometric Hash algorithm are pointed out and possible countermeasures are proposed.
Document type :
Conference papers
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01056380
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, August 18, 2014 - 6:07:27 PM
Last modification on : Monday, March 26, 2018 - 10:38:06 AM
Long-term archiving on: : Thursday, November 27, 2014 - 5:33:08 AM
File
cms2010_submission_34.pdf
Identifiers
Citation
Karl Kümmel, Claus Vielhauer, Tobias Scheidat, Dirk Franke, Jana Dittmann. Handwriting Biometric Hash Attack: A Genetic Algorithm with User Interaction for Raw Data Reconstruction. 11th IFIP TC 6/TC 11 International Conference on Communications and Multimedia Security (CMS), May 2010, Linz, Austria. pp.178-190, ⟨10.1007/978-3-642-13241-4_17⟩. ⟨hal-01056380⟩
Share
Metrics
Record views
624
Files downloads
579
