Conference papers
Grouping Nodes in Wireless Sensor Networks Using Coalitional Game Theory
Abstract : Wireless sensor networks are typically ad-hoc networks of resource-constrained nodes; in particular, the nodes are limited in power resources. It can be difficult and costly to replace sensor nodes, for instance when implanted in the human body. Data transmission is the major consumer of power, so it is important to have power-efficient protocols. In order to reduce the total power consumption in the network, we consider nodes which cooperate to transmit data. Nodes which cooperate, form a group. A mobile node may at some point be without a group, in which case it is desirable for the node to be able to join a group. In this paper we propose a modification of the AODV protocol to decide whether a node should join a given group, using coalitional game theory to determine what is beneficial in terms of power consumption. The protocol is formalized in rewriting logic, implemented in the Maude tool, and validated by means of Maude's model exploration facilities.
Document type :
Conference papers
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-01055142
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, August 11, 2014 - 4:17:10 PM
Last modification on : Tuesday, February 23, 2021 - 7:24:05 PM
Long-term archiving on: : Tuesday, April 11, 2017 - 7:28:18 PM
File
61170093.pdf
Identifiers
Citation
Fatemeh Kazemeyni, Einar Broch Johnsen, Olaf Owe, Ilangko Balasingham. Grouping Nodes in Wireless Sensor Networks Using Coalitional Game Theory. Joint 12th IFIP WG 6.1 International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 30th IFIP WG 6.1 International Conference on Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2010, Amsterdam, Netherlands. pp.95-109, ⟨10.1007/978-3-642-13464-7_9⟩. ⟨hal-01055142⟩
Share
Metrics
Record views
135
Files downloads
131
