Formal Techniques for Distributed Systems 12th IFIP WG 6.1 International Conference FMOODS 2010 and 30th IFIP WG 6.1 International Conference FORTE 2010, Amsterdam, The Netherlands, June 7-9, 2010
Abstract : Timed automata theory is well developed in literature. This theory provides a formal framework to model and test real-time systems. This formal framework supplies a way to describe transitions among states with timing constrains. These constraints are usually expressed with logic formulas involving the system clocks. The time domain of these clocks usually is considered dense, that is, the clocks take values in the real or rational numbers. Dealing with a domain like this can be hard, specially if we consider end points of intervals. In this paper, we present a modification of the model that allows to use real time in an easier, more powerful and reliable approach for computing systems. Our proposed model exploits the concepts of fuzzy set theory and related mathematical frameworks to get a more flexible approach.
https://hal.inria.fr/hal-01055157 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, August 11, 2014 - 4:33:52 PM Last modification on : Tuesday, October 19, 2021 - 3:44:45 PM Long-term archiving on: : Wednesday, November 26, 2014 - 10:15:58 PM
F. Javier Crespo, Alberto Encina, Luis Llana. Fuzzy-Timed Automata. Joint 12th IFIP WG 6.1 International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 30th IFIP WG 6.1 International Conference on Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2010, Amsterdam, Netherlands. pp.140-154, ⟨10.1007/978-3-642-13464-7_12⟩. ⟨hal-01055157⟩
