Formal Techniques for Distributed Systems 12th IFIP WG 6.1 International Conference FMOODS 2010 and 30th IFIP WG 6.1 International Conference FORTE 2010, Amsterdam, The Netherlands, June 7-9, 2010
Abstract : We propose a new simulation-based technique for verifying applications running within a large heterogeneous system. Our technique starts by performing simulations of the system in order to learn the context in which the application is used. Then, it creates a stochastic abstraction for the application, which takes the context information into account. This smaller model can be verified using efficient techniques such as statistical model checking. We have applied our technique to an industrial case study: the cabin communication system of an airplane. We use the BIP toolset to model and simulate the system. We have conducted experiments to verify the clock synchronization protocol i.e., the application used to synchronize the clocks of all computing devices within the system.
https://hal.inria.fr/inria-00554321 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, August 11, 2014 - 4:23:25 PM Last modification on : Friday, February 4, 2022 - 3:09:29 AM Long-term archiving on: : Wednesday, November 26, 2014 - 10:11:35 PM
Ananda Basu, Saddek Bensalem, Marius Bozga, Benoît Caillaud, Benoît Delahaye, et al.. Statistical Abstraction and Model-Checking of Large Heterogeneous Systems. Joint 12th IFIP WG 6.1 International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 30th IFIP WG 6.1 International Conference on Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2010, Amsterdam, Netherlands. pp.32-46, ⟨10.1007/978-3-642-13464-7_4⟩. ⟨inria-00554321v2⟩
