Full Text Documents
Chargement de la page
Search
Table of Contents
Networked Services and Applications - Engineering, Control and Management
Finn Aagesen, Svein Johan Knapskog
Front Matter
Admission Control and Networking
On the Performance of Grooming Strategies for Offloading IP Flows onto Lightpaths in Hybrid Networks
Rudolf Biesbroek, Tiago Fioreze, Lisandro Zambenedetti Granville, Aiko Pras
1-10
MBAC: Impact of the Measurement Error on Key Performance Issues
Anne Nevin, Peder J. Emstad, Yuming Jiang
11-20
An Algorithm for Automatic Base Station Placement in Cellular Network Deployment
István Törős, Péter Fazekas
21-30
An Energy-Efficient FPGA-Based Packet Processing Framework
Daniel Horvath, Imre Bertalan, Istvan Moldován, Tuan Anh Trinh
31-40
Service Mobility
Service Migration Protocol for NFC Links
Anders Nickelsen, Miquel Martin, Hans-Peter Schwefel
41-50
Swarm Intelligence Heuristics for Component Deployment
Máté J. Csorba, Poul E. Heegaard
51-64
Peer-to-Peer and Virtualization
On Force-Based Placement of Distributed Services within a Substrate Network
Laurie Lallemand, Andreas Reifert
65-75
Enabling P2P Gaming with Network Coding
Balázs Lajtha, Gergely Biczók, Róbert Szabó
76-86
A Virtual File System Interface for Computational Grids
Abdulrahman Azab, Hein Meling
87-96
Security
Labeled VoIP Data-set for Intrusion Detection Evaluation
Mohamed Nassar, State Radu, Olivier Festor
97-106
Document Provenance in the Cloud: Constraints and Challenges
Mohamed Amin Sakka, Bruno Defude, Jorge Tellez
107-117
Wireless Handoff Optimization: A Comparison of IEEE 802.11r and HOKEY
Kashif Nizam Khan, Jinat Rehana
118-131
Introducing Perfect Forward Secrecy for AN.ON
Benedikt Westermann, Dogan Kesdogan
132-142
Congestion Control
Mobility-Aware Drop Precedence Scheme in DiffServ-Enabled Mobile Network Systems
Bongkyo Moon
143-154
Theoretical Analysis of an Ideal Startup Scheme in Multihomed SCTP
Johan Eklund, Karl-Johan Grinnemo, Anna Brunstrom
155-166
Monitoring and Filtering
The Network Data Handling War: MySQL vs. NfDump
Rick Hofstede, Anna Sperotto, Tiago Fioreze, Aiko Pras
167-176
Processing of Flow Accounting Data in Java: Framework Design and Performance Evaluation
Jochen Kögel, Sebastian Scholz
177-187
Fighting Spam on the Sender Side: A Lightweight Approach
Wouter Willem Vries, Giovane Cesar Moreira Moura, Aiko Pras
188-197
Dependability
Degradation Model for Erbium-Doped Fiber Amplifiers to Reduce Network Downtime
Christian Merkle
198-208
A Token Based Approach Detecting Downtime in Distributed Application Servers or Network Elements
Sune Jakobsson
209-216
Distributed Resource Reservation for Beacon Based MAC Protocols
Frank Leipold, Jörg Eberspächer
217-225
Adaptation and Reconfiguration
On Runtime Adaptation of Application-Layer Multicast Protocol Parameters
Christian Hübsch, Christoph P. Mayer, Oliver P. Waldhorst
226-235
A Framework with Proactive Nodes for Scheduling and Optimizing Distributed Embedded Systems
Adrián Noguero, Isidro Calvo
236-245
Resource Adaptive Distributed Information Sharing
Hans Vatne Hansen, Vera Goebel, Thomas Plagemann, Matti Siekkinen
246-255
Poster Session
Performance Impacts of Node Failures on a Chord-Based Hierarchical Peer-to-Peer Network
Quirin Hofstätter
256-258
A Low-Power Scheme for Localization in Wireless Sensor Networks
Jorge Juan Robles, Sebastian Tromer, Monica Quiroga, Ralf Lehnert
259-262
Flow Aggregation Using Dynamic Packet State
Addisu Eshete, Yuming Jiang
263-265
Evaluating MDC with Incentives in P2PTV Systems
Alberto J. Gonzalez, Andre Rios, Guillermo Enero, Antoni Oller, Jesus Alcober
266-269
Translation from UML to SPN Model: A Performance Modeling Framework
Razib Hayat Khan, Poul E. Heegaard
270-271
An Open and Extensible Service Discovery for Ubiquitous Communication Systems
Nor Shahniza Kamal Bashah, Ivar Jørstad, Do Thanh
272-273
