HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Full Text Documents
Chargement de la page
Search
Table of Contents
Network and Parallel Computing
Chen Ding, Zhiyuan Shao, Ran Zheng
Front Matter
Keynote Speech
Building a Domain-Knowledge Guided System Software Environment to Achieve High-Performance of Multi-core Processors
Xiaodong Zhang
1-1
Internet-Based Virtual Computing Environment
Huaimin Wang
2-2
Parallelization and Optimization
Vectorization for Java
Jiutao Nie, Buqi Cheng, Shisheng Li, Ligang Wang, Xiao-Feng Li
3-17
Just-in-Time Compiler Assisted Object Reclamation and Space Reuse
Yu Zhang, Lina Yuan, Tingpeng Wu, Wen Peng, Quanlong Li
18-34
Optimization of Triangular Matrix Functions in BLAS Library on Loongson2F
Yun Xu, Mingzhi Shao, Da Teng
35-45
Exposing Tunable Parameters in Multi-threaded Numerical Code
Apan Qasem, Jichi Guo, Faizur Rahman, Qing Yi
46-60
LU Decomposition on Cell Broadband Engine: An Empirical Study to Exploit Heterogeneous Chip Multiprocessors
Feng Mao, Xipeng Shen
61-75
FDTM: Block Level Data Migration Policy in Tiered Storage System
Xiaonan Zhao, Zhanhuai Li, Leijie Zeng
76-90
Parallel Algorithms
Scale-Adaptable Recrawl Strategies for DHT-based Distributed Web Crawling System
Xiao Xu, Weizhe Zhang, Hongli Zhang, Binxing Fang
91-105
Power Efficient Scheduling for Hard Real-Time Systems on a Multiprocessor Platform
Peter J. Nistler, Jean-Luc Gaudiot
106-120
Storage Device Performance Prediction with Selective Bagging Classification and Regression Tree
Lei Zhang, Guiquan Liu, Xuechen Zhang, Song Jiang, Enhong Chen
121-133
Embedding Algorithms for Bubble-Sort, Macro-Star, and Transposition Graphs
Hyeongok Lee, Dongwan Kim, Junghyun Seo, Mihye Kim
134-143
An Efficient Simulation Algorithm for Cache of Random Replacement Policy
Shuchang Zhou
144-154
DABGPM: A Double Auction Bayesian Game-based Pricing Model in Cloud Market
Shifeng Shang, Jinlei Jiang, Yongwei Wu, Zhenchun Huang, Guangwen Yang, Weimin Zheng
155-164
Network
NPA-BT: A Network Performance Aware BitTorrent Traffic Optimization Mechanism
Changyou Xing, Li Yang, Ming Chen
165-176
User Behavior Pattern Analysis and Prediction Based on Mobile Phone Sensors
Jiqiang Song, Eugene Y. Tang, Leibo Liu
177-189
ServiceStore: A Peer-to-Peer Framework for QoS-aware Service Composition
Jun Jin, Yu Zhang, Yuanda Cao, Xing Pu, Jiaxin Li
190-199
Identifying Nearest Neighbor Nodes and Connectivity in Three-Dimensional Wireless Sensor Networks Using Poisson Point Field
Yanhuai Qu, Jianan Fang, Shuai Zhang
200-209
A Novel Trust Evaluation Model for Mobile P2P Networks
Xu Wu
210-219
Parallelization and Optimization (Cluster)
Evaluating and Optimizing I/O Virtualization in Kernel-based Virtual Machine (KVM)
Binbin Zhang, Xiaolin Wang, Rongfeng Lai, Liang Yang, Zhenlin Wang, Yingwei Luo, Xiaoming Li
220-231
Distributed Stream Processing with DUP
Kai Christian Bader, Tilo Eißler, Nathan Evans, Chris Gauthierdickey, Christian Grothoff, Krista Grothoff, Jeff Keene, Harald Meier, Craig Ritzdorf, Matthew J. Rutherford
232-246
CCIndex: a Complemental Clustering Index on Distributed Ordered Tables for Multi-dimensional Range Queries
Yongqiang Zou, Jia Liu, Shicai Wang, Li Zha, Zhiwei Xu
247-261
Online Event Correlations Analysis in System Logs of Large-Scale Cluster Systems
Wei Zhou, Jianfeng Zhan, Dan Meng, Zhihong Zhang
262-276
Differentiated Replication Strategy in Data Centers
Tung Nguyen, Anthony Cutway, Weisong Shi
277-288
Efficient Pipelining Parallel Methods for Image Compositing in Sort-Last Rendering
Wei Fang, Guangzhong Sun, Peng Zheng, Tiening He, Guoliang Chen
289-298
GPU and Multicore
memCUDA: Map Device Memory to Host Memory on GPGPU Platform
Hai Jin, Bo Li, Qin Zhang, Wenbing Ao
299-313
Adaptive Line Size Cache for Irregular References on Cell Multicore Processor
Qian Cao, Chongchong Zhao, Junxiu Chen, Yunxing Zhang, Yi Chen
314-328
Software-Hardware Cooperative DRAM Bank Partitioning for Chip Multiprocessors
Wei Mi, Xiaobing Feng, Jingling Xue, Yaocang Jia
329-343
Energy-Efficient Scheduling of Real-Time Periodic Tasks in Multicore Systems
Xiaodong Wu, Yuan Lin, Jian-Jun Han, Jean-Luc Gaudiot
344-357
The Core Degree Based Tag Reduction on Chip Multiprocessor to Balance Energy Saving and Performance Overhead
Long Zheng, Mianxiong Dong, Hai Jin, Minyi Guo, Song Guo, Xuping Tu
358-372
Cloud and Grid Infrastructure
Improve Throughput of Storage Cluster Interconnected with a TCP/IP Network Using Intelligent Server Grouping
Xuechen Zhang, Guiquan Liu, Song Jiang
373-389
Evaluate the Performance and Scalability of Image Deployment in Virtual Data Center
Kejiang Ye, Xiaohong Jiang, Qinming He, Xing Li, Jianhai Chen
390-401
A Resource Discovery Algorithm in Mobile Grid Computing based on IP-paging Scheme
Yue Zhang, Yunxia Pei
402-411
JAMILA: A Usable Batch Job Management System to Coordinate Heterogeneous Clusters and Diverse Applications over Grid or Cloud Infrastructure
Juan Peng, Xiaoyi Lu, Boqun Cheng, Li Zha
412-422
User-Centric Privacy Preservation in Data-Sharing Applications
Feng Gao, Jingsha He, Shufen Peng
423-431
Software Metrics Reduction for Fault-Proneness Prediction of Software Modules
Yunfeng Luo, Kerong Ben, Lei Mi
432-441
Network on Chip
A Methodology for Design of Unbuffered Router Microarchitecture for S-Mesh NoC
Hao Liu, Feifei Cao, Dongsheng Liu, Xuecheng Zou, Zhigang Zhang
442-451
A Worst Case Performance Model for TDM Virtual Circuit in NoCs
Zhipeng Chen, Axel Jantsch
452-461
Convex-Based DOR Routing for Virtualization of NoC
Guang Sun, Yuanyuan Zhang, Yong Li, Li Su, Depeng Jin, Lieguang Zeng
462-469
MPSoC Architecture-Aware Automatic NoC Topology Design
Rachid Dafali, Jean-Philippe Diguet
470-480
ERA: An Efficient Routing Algorithm for Power, Throughput and Latency in Network-on-Chips
Varsha Sharma, Rekha Agarwal, Manoj S. Gaur, Vijay Laxmi, Vineetha V.
481-490
