index - Network and Parallel Computing Access content directly
Full Text Documents
Chargement de la page
Search
Table of Contents
Chen Ding, Zhiyuan Shao, Ran Zheng
Front Matter
Keynote Speech
Building a Domain-Knowledge Guided System Software Environment to Achieve High-Performance of Multi-core Processors
Xiaodong Zhang
1-1
Internet-Based Virtual Computing Environment
Huaimin Wang
2-2
Parallelization and Optimization
Vectorization for Java
Jiutao Nie, Buqi Cheng, Shisheng Li, Ligang Wang, Xiao-Feng Li
3-17
Just-in-Time Compiler Assisted Object Reclamation and Space Reuse
Yu Zhang, Lina Yuan, Tingpeng Wu, Wen Peng, Quanlong Li
18-34
Optimization of Triangular Matrix Functions in BLAS Library on Loongson2F
Yun Xu, Mingzhi Shao, Da Teng
35-45
Exposing Tunable Parameters in Multi-threaded Numerical Code
Apan Qasem, Jichi Guo, Faizur Rahman, Qing Yi
46-60
LU Decomposition on Cell Broadband Engine: An Empirical Study to Exploit Heterogeneous Chip Multiprocessors
Feng Mao, Xipeng Shen
61-75
FDTM: Block Level Data Migration Policy in Tiered Storage System
Xiaonan Zhao, Zhanhuai Li, Leijie Zeng
76-90
Parallel Algorithms
Scale-Adaptable Recrawl Strategies for DHT-based Distributed Web Crawling System
Xiao Xu, Weizhe Zhang, Hongli Zhang, Binxing Fang
91-105
Power Efficient Scheduling for Hard Real-Time Systems on a Multiprocessor Platform
Peter J. Nistler, Jean-Luc Gaudiot
106-120
Storage Device Performance Prediction with Selective Bagging Classification and Regression Tree
Lei Zhang, Guiquan Liu, Xuechen Zhang, Song Jiang, Enhong Chen
121-133
Embedding Algorithms for Bubble-Sort, Macro-Star, and Transposition Graphs
Hyeongok Lee, Dongwan Kim, Junghyun Seo, Mihye Kim
134-143
An Efficient Simulation Algorithm for Cache of Random Replacement Policy
Shuchang Zhou
144-154
DABGPM: A Double Auction Bayesian Game-based Pricing Model in Cloud Market
Shifeng Shang, Jinlei Jiang, Yongwei Wu, Zhenchun Huang, Guangwen Yang, Weimin Zheng
155-164
Network
NPA-BT: A Network Performance Aware BitTorrent Traffic Optimization Mechanism
Changyou Xing, Li Yang, Ming Chen
165-176
User Behavior Pattern Analysis and Prediction Based on Mobile Phone Sensors
Jiqiang Song, Eugene Y. Tang, Leibo Liu
177-189
ServiceStore: A Peer-to-Peer Framework for QoS-aware Service Composition
Jun Jin, Yu Zhang, Yuanda Cao, Xing Pu, Jiaxin Li
190-199
Identifying Nearest Neighbor Nodes and Connectivity in Three-Dimensional Wireless Sensor Networks Using Poisson Point Field
Yanhuai Qu, Jianan Fang, Shuai Zhang
200-209
A Novel Trust Evaluation Model for Mobile P2P Networks
Xu Wu
210-219
Parallelization and Optimization (Cluster)
Evaluating and Optimizing I/O Virtualization in Kernel-based Virtual Machine (KVM)
Binbin Zhang, Xiaolin Wang, Rongfeng Lai, Liang Yang, Zhenlin Wang, Yingwei Luo, Xiaoming Li
220-231
Distributed Stream Processing with DUP
Kai Christian Bader, Tilo Eißler, Nathan Evans, Chris Gauthierdickey, Christian Grothoff, Krista Grothoff, Jeff Keene, Harald Meier, Craig Ritzdorf, Matthew J. Rutherford
232-246
CCIndex: a Complemental Clustering Index on Distributed Ordered Tables for Multi-dimensional Range Queries
Yongqiang Zou, Jia Liu, Shicai Wang, Li Zha, Zhiwei Xu
247-261
Online Event Correlations Analysis in System Logs of Large-Scale Cluster Systems
Wei Zhou, Jianfeng Zhan, Dan Meng, Zhihong Zhang
262-276
Differentiated Replication Strategy in Data Centers
Tung Nguyen, Anthony Cutway, Weisong Shi
277-288
Efficient Pipelining Parallel Methods for Image Compositing in Sort-Last Rendering
Wei Fang, Guangzhong Sun, Peng Zheng, Tiening He, Guoliang Chen
289-298
GPU and Multicore
memCUDA: Map Device Memory to Host Memory on GPGPU Platform
Hai Jin, Bo Li, Qin Zhang, Wenbing Ao
299-313
Adaptive Line Size Cache for Irregular References on Cell Multicore Processor
Qian Cao, Chongchong Zhao, Junxiu Chen, Yunxing Zhang, Yi Chen
314-328
Software-Hardware Cooperative DRAM Bank Partitioning for Chip Multiprocessors
Wei Mi, Xiaobing Feng, Jingling Xue, Yaocang Jia
329-343
Energy-Efficient Scheduling of Real-Time Periodic Tasks in Multicore Systems
Xiaodong Wu, Yuan Lin, Jian-Jun Han, Jean-Luc Gaudiot
344-357
The Core Degree Based Tag Reduction on Chip Multiprocessor to Balance Energy Saving and Performance Overhead
Long Zheng, Mianxiong Dong, Hai Jin, Minyi Guo, Song Guo, Xuping Tu
358-372
Cloud and Grid Infrastructure
Improve Throughput of Storage Cluster Interconnected with a TCP/IP Network Using Intelligent Server Grouping
Xuechen Zhang, Guiquan Liu, Song Jiang
373-389
Evaluate the Performance and Scalability of Image Deployment in Virtual Data Center
Kejiang Ye, Xiaohong Jiang, Qinming He, Xing Li, Jianhai Chen
390-401
A Resource Discovery Algorithm in Mobile Grid Computing based on IP-paging Scheme
Yue Zhang, Yunxia Pei
402-411
JAMILA: A Usable Batch Job Management System to Coordinate Heterogeneous Clusters and Diverse Applications over Grid or Cloud Infrastructure
Juan Peng, Xiaoyi Lu, Boqun Cheng, Li Zha
412-422
User-Centric Privacy Preservation in Data-Sharing Applications
Feng Gao, Jingsha He, Shufen Peng
423-431
Software Metrics Reduction for Fault-Proneness Prediction of Software Modules
Yunfeng Luo, Kerong Ben, Lei Mi
432-441
Network on Chip
A Methodology for Design of Unbuffered Router Microarchitecture for S-Mesh NoC
Hao Liu, Feifei Cao, Dongsheng Liu, Xuecheng Zou, Zhigang Zhang
442-451
A Worst Case Performance Model for TDM Virtual Circuit in NoCs
Zhipeng Chen, Axel Jantsch
452-461
Convex-Based DOR Routing for Virtualization of NoC
Guang Sun, Yuanyuan Zhang, Yong Li, Li Su, Depeng Jin, Lieguang Zeng
462-469
MPSoC Architecture-Aware Automatic NoC Topology Design
Rachid Dafali, Jean-Philippe Diguet
470-480
ERA: An Efficient Routing Algorithm for Power, Throughput and Latency in Network-on-Chips
Varsha Sharma, Rekha Agarwal, Manoj S. Gaur, Vijay Laxmi, Vineetha V.
481-490
