Conference papers
Generating Models of Infinite-State Communication Protocols using Regular Inference with Abstraction
Abstract : In order to facilitate model-based verification and validation, effort is underway to develop techniques for generating models of communication system components from observations of their external behavior. Most previous such work has employed regular inference techniques which generate modest-size finite-state models. They typically suppress parameters of messages, although these have a significant impact on control fow in many communication protocols. We present a framework, which adapts regular inference to include data parameters in messages and states for generating components with large or infinite message alphabets. A main idea is to adapt the framework of predicate abstraction, successfully used in formal verification. Since we are in a black-box setting, the abstraction must be supplied externally, using information about how the component manages data parameters. We have implemented our techniques by connecting the LearnLib tool for regular inference with the protocol simulator ns-2, and generated a model of the SIP component as implemented in ns-2.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00767416
Contributor : Sofia Cassel Connect in order to contact the contributor
Submitted on : Wednesday, December 19, 2012 - 5:57:41 PM
Last modification on : Tuesday, July 23, 2019 - 1:12:54 AM
Links full text
Identifiers
Collections
Citation
Fides Aarts, Bengt Jonsson, Johan Uijen. Generating Models of Infinite-State Communication Protocols using Regular Inference with Abstraction. IFIP International Conference on Testing Software and Systems (ICTSS), Nov 2010, Natal, Brazil. pp.188-204, ⟨10.1007/978-3-642-16573-3_14⟩. ⟨hal-00767416⟩
Share
Metrics
Record views
321
