Conference papers
Black-Box System Testing of Real-Time Embedded Systems Using Random and Search-based Testing
Abstract : Testing real-time embedded systems (RTES) is in many ways challenging. Thousands of test cases can be potentially executed on an industrial RTES. Given the magnitude of testing at the system level, only a fully automated approach can really scale up to test industrial RTES. In this paper we take a black-box approach and model the RTES environment using the UML/MARTE international standard. Our main motivation is to provide a more practical approach to the model-based testing of RTES by allowing system testers, who are often not familiar with the system design but know the application domain well-enough, to model the environment to enable test automation. Environment models can support the automation of three tasks: the code generation of an environment simulator, the selection of test cases, and the evaluation of their expected results (oracles). In this paper, we focus on the second task (test case selection) and investigate three test automation strategies using inputs from UML/MARTE environment models: Random Testing (baseline), Adaptive Random Testing, and Search-Based Testing (using Genetic Algorithms). Based on one industrial case study and three artificial systems, we show how, in general, no technique is better than the others. Which test selection technique to use is determined by the failure rate (testing stage) and the execution time of test cases. Finally, we propose a practical process to combine the use of all three test strategies.
Document type :
Conference papers
Complete list of metadata
Cited literature [27 references]  Display  Hide  Download
https://hal.inria.fr/hal-01055241
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, August 12, 2014 - 9:25:49 AM
Last modification on : Tuesday, February 18, 2020 - 2:11:07 PM
Long-term archiving on: : Wednesday, November 26, 2014 - 10:35:32 PM
File
64350094.pdf
Identifiers
Citation
Andrea Arcuri, Muhammad Zohaib Iqbal, Lionel Briand. Black-Box System Testing of Real-Time Embedded Systems Using Random and Search-based Testing. 22nd IFIP WG 6.1 International Conference on Testing Software and Systems (ICTSS), Nov 2010, Natal, Brazil. pp.95-110, ⟨10.1007/978-3-642-16573-3_8⟩. ⟨hal-01055241⟩
Share
Metrics
Record views
529
Files downloads
1440
