Conference papers
Compositional Random Testing Using Extended Symbolic Transition Systems
Abstract : The fast growth in complexity of embedded and software enabled systems requires for automated testing strategies to achieve a high system quality. This raise of complexity is often caused by the distribution of functionality over multiple control units and their connection via a network. We define an extended symbolic transition system (ESTS) and their compositional semantics to reflect these new requirements imposed on the test generation methods. The introduced ESTS incorporates timed behavior by transition execution times and delay transitions. Their timeout can be defined either by a constant value or an attribute valuation. Moreover we introduce a communication scheme used to specify the compositional behavior and define a conformance relation based on alternating simulation. Furthermore we use the conformance relation as the basis for a simple random test generation technique to verify the applicability of the presented approach. This formal framework builds the foundation of our UML test case generator.
Complete list of metadatas
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01583918
Contributor : Hal Ifip <>
Submitted on : Friday, September 8, 2017 - 10:05:28 AM
Last modification on : Friday, September 8, 2017 - 10:08:39 AM
File
978-3-642-24580-0_13_Chapter.p...
Identifiers
Citation
Christian Schwarzl, Bernhard Aichernig, Franz Wotawa. Compositional Random Testing Using Extended Symbolic Transition Systems. 23th International Conference on Testing Software and Systems (ICTSS), Nov 2011, Paris, France. pp.179-194, ⟨10.1007/978-3-642-24580-0_13⟩. ⟨hal-01583918⟩
Share
Metrics
Record views
101
Files downloads
155
