Conference papers
GPU-Assisted AES Encryption Using GCM
Abstract : We are presenting an implementation of the Galois/Counter Mode (GCM) for the Advanced Encryption Standard (AES) in IPsec in this paper. GCM is a so called “authenticated encryption” as it can ensure confidentiality, integrity and authentication. It uses the Counter Mode for encryption, therefore counters are encrypted for an exclusive-OR with the plaintext. We describe a technique where these encryptions are precomputed on a Graphic Processing Unit (GPU) and can later be used to encrypt the plaintext, whereupon only the exclusive-OR and authentication part of GCM are left to be computed. This technique should primarily not limit the performance to the speed of the AES implementation but allow Gigabit throughput and at the same time minimize the CPU load.
Complete list of metadatas
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01596207
Contributor : Hal Ifip <>
Submitted on : Wednesday, September 27, 2017 - 1:50:28 PM
Last modification on : Wednesday, September 27, 2017 - 1:51:51 PM
Long-term archiving on: : Thursday, December 28, 2017 - 2:01:10 PM
File
978-3-642-24712-5_16_Chapter.p...
Identifiers
Citation
Georg Schönberger, Jürgen Fuß. GPU-Assisted AES Encryption Using GCM. 12th Communications and Multimedia Security (CMS), Oct 2011, Ghent, Belgium. pp.178-185, ⟨10.1007/978-3-642-24712-5_16⟩. ⟨hal-01596207⟩
Share
Metrics
Record views
472
Files downloads
319
