Formal Techniques for Distributed Systems Joint 14th IFIP WG 6.1 International Conference, FMOODS 2012 and 32nd IFIP WG 6.1 International Conference, FORTE 2012 Stockholm, Sweden, June 13-16, 2012
Abstract : Conformance testing is the problem of constructing a complete test suite of inputs based on a specification S such that any implementation I (of size less than a given bound) that is not equivalent to S gives a different output on the test suite than S. Typically I and S are assumed to be some type of finite automata. In this paper we consider the problem of constructing test suites for boolean programs (or more precisely modular visibly pushdown automata) that are guaranteed to catch all erroneous implementations that have at least R faults, and pass all correct implementations; if the incorrect implementation has fewer than R faults then the test suite may or may not detect it. We present a randomized algorithm for the construction of such test suites, and prove the near optimality of our test suites by proving lower bounds on the size of test suites.
Document type :
Conference papers
Holger Giese; Grigore Rosu. 14th International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 32nd International Conference on Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2012, Stockholm, Sweden. Springer, Lecture Notes in Computer Science, LNCS-7273, pp.101-117, 2012, Formal Techniques for Distributed Systems. 〈10.1007/978-3-642-30793-5_7〉
https://hal.inria.fr/hal-01528731
Contributor : Hal Ifip
Submitted on : Monday, May 29, 2017 - 3:53:56 PM
Last modification on : Monday, May 29, 2017 - 3:55:37 PM
Document(s) archivé(s) le : Wednesday, September 6, 2017 - 11:23:08 AM
Pavithra Prabhakar, Mahesh Viswanathan. Conformance Testing of Boolean Programs with Multiple Faults. Holger Giese; Grigore Rosu. 14th International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 32nd International Conference on Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2012, Stockholm, Sweden. Springer, Lecture Notes in Computer Science, LNCS-7273, pp.101-117, 2012, Formal Techniques for Distributed Systems. 〈10.1007/978-3-642-30793-5_7〉. 〈hal-01528731〉
