Conference papers
Short Term Template Aging Effects on Biometric Dynamic Handwriting Authentication Performance
Abstract : In biometrics the variance between data acquired from the same user and same trait is not only based on different sensors or user’s form of the day, but it also depends on an aging factor. Over time the biological characteristics of a human body changes. This leads to physical and mental alternations, which may have significant influence on the biometric authentication process. In order to parameterize a biometric system, the study of the degree of aging’s influence is an important step. In this paper we provide an experimental evaluation on the influence of changes of handwriting biometrics by acquiring data from writers in three sessions with a time difference of one month each. The aim is to analyze the potential impact of aging processes on different written content within a biometric handwriting system in terms of authentication performance. In the worst case, the equal error rate determined on verification data acquired two month after the reference data (EER = 0.162) is four times higher than the equal error rate calculated based on reference and verification data from the first session (EER = 0.041).
Complete list of metadata
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01540884
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, June 16, 2017 - 4:46:57 PM
Last modification on : Friday, February 23, 2018 - 10:42:09 AM
Long-term archiving on: : Wednesday, January 10, 2018 - 1:22:31 PM
File
978-3-642-32805-3_9_Chapter.pd...
Identifiers
Citation
Tobias Scheidat, Karl Kümmel, Claus Vielhauer. Short Term Template Aging Effects on Biometric Dynamic Handwriting Authentication Performance. 13th International Conference on Communications and Multimedia Security (CMS), Sep 2012, Canterbury, United Kingdom. pp.107-116, ⟨10.1007/978-3-642-32805-3_9⟩. ⟨hal-01540884⟩
Share
Metrics
Les métriques sont temporairement indisponibles
