Conference papers
SNR-Based Partial Relay Selection Scheme over Multiple Relay Network
Abstract : In this paper we propose a sub-optimal relay selection scheme over a multiple relay network where the relay node is selected if its link quality is above a certain threshold which is set to satisfy the required performance and the selected link is maintained unless its link quality does not fall below the threshold. From our derived statistics of the received output signal-to-noise ratio (SNR), we derive the end-to-end system performance in terms of the outage probability. In addition, we apply our proposed algorithm to the selection decode-and-forward protocol, and analyze its outage performances. We show from our numerical example that our proposed algorithm can provide adequate performance by setting the moderate threshold while its complexity is much lower than the one of an optimal relay selection scheme.
Document type :
Conference papers
Complete list of metadatas
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-01551316
Contributor : Hal Ifip <>
Submitted on : Friday, June 30, 2017 - 10:35:35 AM
Last modification on : Thursday, March 5, 2020 - 5:40:34 PM
Document(s) archivé(s) le : Monday, January 22, 2018 - 7:07:03 PM
File
978-3-642-35606-3_72_Chapter.p...
Identifiers
Citation
Kyu-Sung Hwang. SNR-Based Partial Relay Selection Scheme over Multiple Relay Network. 9th International Conference on Network and Parallel Computing (NPC), Sep 2012, Gwangju, South Korea. pp.608-615, ⟨10.1007/978-3-642-35606-3_72⟩. ⟨hal-01551316⟩
Share
Metrics
Record views
94
Files downloads
194
