Conference papers
Relative Priority Analysis of Korean IS Audit Standard Check Items Using the Constant-Sum Method
Abstract : Currently, our country have introduced IS audit system to manage and supervise stable development and efficient operation of the IS. IT audit is accomplished by IS auditor using standard check items made by our government. As IT paradigm drastically changes and user’s IT service demands level is high, Flexible change or modification of standard check items is inevitable. It is reasonable to change or modify them according to the priority after establishing relative weight inter-standard check items. To do this, domestic standard check items are represented as hierarchical structure using Hierarchical Decision Model (HDM) and relative weights and priority among them are obtained by Constant-sum Method in this paper. This result will give a logical validity enough to modify or change domestic standard check items.
Document type :
Conference papers
Complete list of metadatas
https://hal.inria.fr/hal-01551367
Contributor : Hal Ifip <>
Submitted on : Friday, June 30, 2017 - 10:36:14 AM
Last modification on : Thursday, March 5, 2020 - 5:40:41 PM
Document(s) archivé(s) le : Monday, January 22, 2018 - 8:44:26 PM
File
978-3-642-35606-3_27_Chapter.p...
Identifiers
Citation
Boo-Hyoung Lee, Chi-Su Kim, Heon-Tag Kong. Relative Priority Analysis of Korean IS Audit Standard Check Items Using the Constant-Sum Method. 9th International Conference on Network and Parallel Computing (NPC), Sep 2012, Gwangju, South Korea. pp.233-240, ⟨10.1007/978-3-642-35606-3_27⟩. ⟨hal-01551367⟩
Share
Metrics
Record views
84
Files downloads
153
