Conference papers
Early-Detection System for Cross-Language (Translated) Plagiarism
Abstract : The implementation of internet applications has already crossed the language border. It has, for sure, brought lots of advantages, but to some extent has also introduced some side-effect. One of the negative effects of using these applications is cross-languages plagiarism, which is also known as translated plagiarism.In academic institutions, translated plagiarism can be found in various cases, such as: final project, theses, papers, and so forth. In this paper, a model for web-based early detection system for translated plagiarism is proposed and a prototype is developed. The system works by translating the input document (written in Bahasa Indonesian) into English using Google Translate API components, and then search for documents on the World Wide Web repository which have similar contents to the translated document. If found, the system downloads these documents and then do some preprocessing steps such as: removing punctuations, numbers, stop words, repeated words, lemmatization of words, and the final process is to compare the content of both documents using the modified sentence-based detection algorithm (SBDA). The results show that the proposed method has smaller error rate leading to conclusion that it has better accuracy.
Complete list of metadata
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01480193
Contributor : Hal Ifip <>
Submitted on : Wednesday, March 1, 2017 - 11:05:34 AM
Last modification on : Thursday, March 2, 2017 - 1:04:26 AM
Long-term archiving on: : Tuesday, May 30, 2017 - 2:44:46 PM
File
978-3-642-36818-9_3_Chapter.pd...
Identifiers
Citation
Khabib Mustofa, Yosua Sir. Early-Detection System for Cross-Language (Translated) Plagiarism. 1st International Conference on Information and Communication Technology (ICT-EurAsia), Mar 2013, Yogyakarta, Indonesia. pp.21-30, ⟨10.1007/978-3-642-36818-9_3⟩. ⟨hal-01480193⟩
Share
Metrics
Record views
124
Files downloads
808
