Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Full Text Documents
Chargement de la page
Search
Table of Contents
Computer Information Systems and Industrial Management
Khalid Saeed, Rituparna Chaki, Agostino Cortesi, Sławomir Wierzchoń (Eds.)
Front Matter
Full Keynote Papers
What is the Value of Information - Search Engine’s Point of View
Mieczysław Kłopotek
1-12
Application of Combined Classifiers to Data Stream Classification
Michał Woźniak
13-23
Invited Paper
Efficacy of Some Primary Discriminant Functions in Diagnosing Planetary Gearboxes
Anna Bartkowiak, Radoslaw Zimroz
24-35
Biometrics and Biometrics Applications
Identification of Persons by Virtue of Hand Geometry
Anna Plichta, Tomasz Gaciarz, Szymon Szomiński
36-46
User Authentication for Mobile Devices
Marcin Rogowski, Khalid Saeed, Mariusz Rybnik, Marek Tabedzki, Marcin Adamski
47-58
Modified kNN Algorithm for Improved Recognition Accuracy of Biometrics System Based on Gait
Marcin Derlatka
59-66
An Application of the Curvature Scale Space Shape Descriptor for Forensic Human Identification Based on Orthopantomograms
Dariusz Frejlichowski, Piotr Czapiewski
67-76
The Impact of Temporal Proximity between Samples on Eye Movement Biometric Identification
Paweł Kasprowski
77-87
Biomedical Distributed Signal Processing and Analysis
Marek Penhaker, Vladimir Kasik, Vaclav Snasel
88-95
Effect of Slice Thickness on Texture-Based Classification of Liver Dynamic CT Scans
Dorota Duda, Marek Kretowski, Johanne Bezy-Wendling
96-107
Independent Component Analysis for EEG Data Preprocessing - Algorithms Comparison
Izabela Rejer, Paweł Górski
108-119
An Adequate Representation of Medical Data Based on Partial Set Approximation
Zoltán Csajbók, Tamás Mihálydeák, József Ködmön
120-128
Pattern Recognition and Image Processing
Bengali Printed Character Recognition – A New Approach
Soharab Shaikh, Marek Tabedzki, Nabendu Chaki, Khalid Saeed
129-140
Eye Location and Eye State Detection in Facial Images Using Circular Hough Transform
Ömer Söylemez, Burhan Ergen
141-147
Recognition of Occluded Faces Based on Multi-subspace Classification
Paweł Forczmański, Piotr Łabędź
148-157
Mahalanobis Distance-Based Algorithm for Ellipse Growing in Iris Preprocessing
Krzysztof Misztal, Jacek Tabor
158-167
The Data Exploration System for Image Processing Based on Server-Side Operations
Magdalena Ładniak, Adam Piórkowski, Mariusz Młynarczuk
168-176
Image Restoration Using Anisotropic Stochastic Diffusion Collaborated with Non Local Means
Dariusz Borkowski, Katarzyna Jańczak-Borkowska
177-189
Various Aspects of Computer Security
A Practical Certificate and Identity Based Encryption Scheme and Related Security Architecture
Tomasz Hyla, Jerzy Pejaś
190-205
Study of Security Issues in Pervasive Environment of Next Generation Internet of Things
Tapalina Bhattasali, Rituparna Chaki, Nabendu Chaki
206-217
Security Issues of IPv6 Network Autoconfiguration
Maciej Rostański, Taras Mushynskyy
218-228
Security Aspects of Virtualization in Cloud Computing
Muhammad Kazim, Rahat Masood, Muhammad Shibli, Abdul Abbasi
229-240
Threshold Method of Detecting Long-Time TPM Synchronization
Michał Dolecki, Ryszard Kozera
241-252
The Removal of False Detections from Foreground Regions Extracted Using Adaptive Background Modelling for a Visual Surveillance System
Dariusz Frejlichowski, Katarzyna Gościewska, Paweł Forczmański, Adam Nowosielski, Radosław Hofman
253-264
Using Backward Induction Techniques in (Timed) Security Protocols Verification
Mirosław Kurkowski, Olga Siedlecka-Lamch, Paweł Dudek
265-276
Telecommunications Networks Risk Assessment with Bayesian Networks
Marcin Szpyrka, Bartosz Jasiul, Konrad Wrona, Filip Dziedzic
277-288
Networking
Power Aware Cluster Based Routing (PACBR) Protocol for Wireless Sensor Network
Ayan Das, Rituparna Chaki, Atreyee Biswas
289-300
A Novel Incentive Based Scheme to Contain Selective Forwarding in Wireless Sensor Network
Saswati Mukherjee, Matangini Chattopadhyay, Samiran Chattopadhyay, Debarshi Sanyal, Roshni Neogy, Samanwita Pal
301-312
Synthetic Social Network Based on Competency-Based Description of Human Resources
Štěpán Kuchař, Jan Martinovič, Pavla Dráždilová, Kateřina Slaninová
313-324
Displaying Genealogy with Adoptions and Multiple Remarriages Using the WHIteBasE
Seiji Sugiyama, Atsushi Ikuta, Daisuke Yokozawa, Miyuki Shibata, Tohru Matsuura
325-336
User Relevance for Item-Based Collaborative Filtering
R. Latha, R. Nadarajan
337-347
Extraction of Agent Groups with Similar Behaviour Based on Agent Profiles
Kateřina Slaninová, Jan Martinovič, Roman Šperka, Pavla Dráždilová
348-357
Algorithms
Aesthetic Patterns from the Perturbed Orbits of Discrete Dynamical Systems
Krzysztof Gdawiec
358-366
Weighted Approach to Projective Clustering
Przemysław Spurek, Jacek Tabor, Krzysztof Misztal
367-378
Machine Learning with Known Input Data Uncertainty Measure
Wojciech Czarnecki, Igor Podolak
379-388
Learning Algorithms in the Detection of Unused Functionalities in SOA Systems
Ilona Bluemke, Marcin Tarka
389-400
Construction of Sequential Classifier Using Confusion Matrix
Robert Burduk, Pawel Trajdos
401-407
Growing Neural Gas – A Parallel Approach
Lukáš Vojáček, Jiří Dvorský
408-419
Modified Moment Method Estimator for the Shape Parameter of Generalized Gaussian Distribution for a Small Sample Size
Robert Krupiński
420-429
Trajectory Estimation for Exponential Parameterization and Different Samplings
Ryszard Kozera, Lyle Noakes, Piotr Szmielew
430-441
Searching in the Structured Space of the Braille Music
Wladyslaw Homenda, Mariusz Rybnik
442-452
Industrial Applications
Solving Steel Alloying Using Differential Evolution and SOMA
Michal Holiš, Lenka Skanderová, Martin Placěk, Jiří Dvorský, Ivan Zelinka
453-464
The Cost Estimation of Production Orders
Tomasz Chlebus
465-475
Achieving Desired Cycle Times by Modelling Production Systems
Marcin Juszczyński, Arkadiusz Kowalski
476-486
Artificial Neural Networks as Tools for Controlling Production Systems and Ensuring Their Stability
Anna Burduk
487-498
Generalized Predictive Control for a Flexible Single-Link Manipulator
Rahma Boucetta
499-510
A Disruption Recovery Model in a Production-Inventory System with Demand Uncertainty and Process Reliability
Sanjoy Paul, Ruhul Sarker, Daryl Essam
511-522
Designed by Inria-IES Team : http://hal.inria.fr/    Hosted by HAL : http://hal.archives-ouvertes.fr/
