Conference papers
Concise Server-Wide Causality Management for Eventually Consistent Data Stores
Abstract : Large scale distributed data stores rely on optimistic replication to scale and remain highly available in the face of network partitions. Managing data without coordination results in eventually consistent data stores that allow for concurrent data updates. These systems often use anti-entropy mechanisms (like Merkle Trees) to detect and repair divergent data versions across nodes. However, in practice hash-based data structures are too expensive for large amounts of data and create too many false conflicts.Another aspect of eventual consistency is detecting write conflicts. Logical clocks are often used to track data causality, necessary to detect causally concurrent writes on the same key. However, there is a non-negligible metadata overhead per key, which also keeps growing with time, proportional with the node churn rate. Another challenge is deleting keys while respecting causality: while the values can be deleted, per-key metadata cannot be permanently removed without coordination.We introduce a new causality management framework for eventually consistent data stores, that leverages node logical clocks (Bitmapped Version Vectors) and a new key logical clock (Dotted Causal Container) to provides advantages on multiple fronts: 1) a new efficient and lightweight anti-entropy mechanism; 2) greatly reduced per-key causality metadata size; 3) accurate key deletes without permanent metadata.
Complete list of metadatas
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-01775033
Contributor : Hal Ifip <>
Submitted on : Tuesday, April 24, 2018 - 11:53:34 AM
Last modification on : Tuesday, April 24, 2018 - 12:42:52 PM
Long-term archiving on: : Wednesday, September 19, 2018 - 8:03:56 AM
File
978-3-319-19129-4_6_Chapter.pd...
Identifiers
Citation
Ricardo Gonçalves, Paulo Almeida, Carlos Baquero, Victor Fonte. Concise Server-Wide Causality Management for Eventually Consistent Data Stores. 15th IFIP International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2015, Grenoble, France. pp.66-79, ⟨10.1007/978-3-319-19129-4_6⟩. ⟨hal-01775033⟩
Share
Metrics
Record views
90
Files downloads
259
