Finding Objects Faster in Dense Environments using a Projection Augmented Robotic Arm
Abstract :
Locating an object in an unfamiliar and dense physical environment, such as a control room, supermarket, or warehouse, can be challenging. In this paper, we present the Projection-Augmented Arm (PAA), a motorized robotic arm augmented with a pico-projector to help users to localize targets in such environments. The arm moves and displays a projected spotlight on the target. We present the results of a study that shows that the PAA helps users to more quickly locate target objects in a dense environment. We further study the influence of the visibility of the projected spotlight while moving versus that of the physical movement of the projection arm on user performance and search strategy, finding that 1) information about the orientation of the arm has a stronger impact on performance however following the moving spotlight on the walls did not significantly improve performance; 2) the orientation of the arm is especially useful when the target is behind the user (36.33 % improvement); and 3) users’ strategies relied mainly on the arm when it is visible.
Document type :
Conference papers
Complete list of metadatas
Cited literature [31 references]  Display  Hide  Download
https://hal-imt.archives-ouvertes.fr/hal-01447396
Contributor : Admin Télécom Paristech <>
Submitted on : Thursday, January 26, 2017 - 6:15:47 PM
Last modification on : Wednesday, October 2, 2019 - 5:30:05 PM
Long-term archiving on : Friday, April 28, 2017 - 8:19:30 AM
File
inproceedings-2015-15503-5.pdf
Identifiers
Citation
Hind Gacem, Gilles Bailly, James Eagan, Eric Lecolinet. Finding Objects Faster in Dense Environments using a Projection Augmented Robotic Arm. INTERACT'15: IFIP International Conference on Human-Computer Interaction, Sep 2015, Bamberg, Germany. pp.221-238, ⟨10.1007/978-3-319-22698-9_15⟩. ⟨hal-01447396⟩
Share
Metrics
Record views
370
Files downloads
161
