A Theory of Integrating Tamper Evidence with Stabilization
Abstract : We propose the notion of tamper-evident stabilization –that combines stabilization with the concept of tamper evidence– for computing systems. On the first glance, these notions are contradictory; stabilization requires that eventually the system functionality is fully restored whereas tamper evidence requires that the system functionality is permanently degraded in the event of tampering. Tamper-evident stabilization captures the intuition that the system will tolerate perturbation upto a limit. In the event that it is perturbed beyond that limit, it will exhibit permanent evidence of tampering, where it may provide reduced (possibly none) functionality. We compare tamper-evident stabilization with (conventional) stabilization and with active stabilization and propose an approach to verify tamper-evident stabilizing programs in polynomial time. We demonstrate tamper-evident stabilization with two examples and argue how approaches for designing stabilization can be used to design tamper-evident stabilization. We also study issues of composition in tamper-evident stabilization. Finally, we point out how tamper-evident stabilization can effectively be used to provide tradeoff between fault-prevention and fault tolerance.
Document type :
Conference papers
Complete list of metadatas
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-01446612
Contributor : Hal Ifip <>
Submitted on : Thursday, January 26, 2017 - 10:43:56 AM
Last modification on : Wednesday, August 7, 2019 - 2:32:05 PM
Long-term archiving on: Friday, April 28, 2017 - 7:17:35 AM
File
978-3-319-24644-4_6_Chapter.pd...
Identifiers
Citation
Reza Hajisheykhi, Ali Ebnenasir, Sandeep Kulkarni. A Theory of Integrating Tamper Evidence with Stabilization. 6th Fundamentals of Software Engineering (FSEN), Apr 2015, Tehran, Iran. pp.84-99, ⟨10.1007/978-3-319-24644-4_6⟩. ⟨hal-01446612⟩
Share
Metrics
Record views
86
Files downloads
282
