Conference papers
Test-Data Generation for Testing Parallel Real-Time Systems
Abstract : The Worst-Case Execution Time (WCET) of real-time systems is mainly influenced by the program design, its execution environment and the input data. To cover the last factor in the context of WCET estimation, the objective of this work is to generate the test-data that maximize the execution times of the parallel real-time systems. In this paper, a test-data generation technique is proposed that uses Genetic Algorithms to automatically generate the input data, to be used for testing of parallel real-time systems. The proposed technique was applied to a parallel embedded application – Stringsearch. The result was an analysis that took as input the parallel program and generated the test-data that cause maximal execution times. The generated test-data showed improvements by exercising long execution times in comparison to randomly generated input data.
Complete list of metadata
Cited literature [29 references]  Display  Hide  Download
https://hal.inria.fr/hal-01470169
Contributor : Hal Ifip <>
Submitted on : Friday, February 17, 2017 - 10:30:50 AM
Last modification on : Friday, February 17, 2017 - 10:37:06 AM
Long-term archiving on: : Thursday, May 18, 2017 - 2:05:54 PM
File
385214_1_En_13_Chapter.pdf
Identifiers
Citation
Muhammad Aziz, Syed Shah. Test-Data Generation for Testing Parallel Real-Time Systems. 27th IFIP International Conference on Testing Software and Systems (ICTSS), Nov 2015, Sharjah and Dubai, United Arab Emirates. pp.211-223, ⟨10.1007/978-3-319-25945-1_13⟩. ⟨hal-01470169⟩
Share
Metrics
Record views
170
Files downloads
288
