Identication of nonlinear modes using phase-locked-loop experimental continuation and normal form - Modélisation, Propagation et Imagerie Acoustique Accéder directement au contenu
Article Dans Une Revue Mechanical Systems and Signal Processing Année : 2018
Identification de modes nonlinéaires par forme normale et continuation expérimentale à base de boucle à verrouillage de phase
In this article, we address the model identication of nonlinear vibratory systems, with a specic focus on systems modeled with distributed nonlinearities, such as geometrically nonlinear mechanical structures. The proposed strategy theoretically relies on the concept of nonlinear modes of the underlying conservative unforced system and the use of normal forms. Within this framework, it is shown that without internal resonance, a valid reduced order model for a nonlinear mode is a single Duffing oscillator. We then propose an efficient experimental strategy to measure the backbone curve of a particular nonlinear mode and we use it to identify the free parameters of the reduced order model. The experimental part relies on a Phase-Locked Loop (PLL) and enables a robust and automatic measurement of backbone curves as well as forced responses. It is theoretically and experimentally shown that the PLL is able to stabilize the unstable part of Duffingng-like frequency responses, thus enabling its robust experimental measurement. Finally, the whole procedure is tested on three experimental systems: a circular plate, a chinese gong and a piezoelectric cantilever beam. It enable to validate the procedure by comparison to available theoretical models as well as to other experimental identication methods.
manuscriptHAL.pdf (21.67 Mo) Télécharger le fichier
hal-01688189 , version 1 (19-01-2018)
  • HAL Id : hal-01688189 , version 1
Vivien Denis, M Jossic, Christophe Giraud-Audine, B. Chomette, A. Renault, et al.. Identication of nonlinear modes using phase-locked-loop experimental continuation and normal form. Mechanical Systems and Signal Processing, In press. ⟨hal-01688189⟩
468 Consultations
104 Téléchargements
