Search
Last submissions
Full text articles
53
Keywords
Ballistic phonons Lamb waves Gallium compounds Periodic structure AQUEOUS-SOLUTION Aluminium GaN nanowires Anisotropy DYNAMICS Electron-phonon interactions EMISSION Gold nanostructures FTIR III-V semiconductors Acoustic transducers Incommensurate phase Metallic thin films Elasticity Core-shell Metal-insulator transition Electrical resistivity Gold nanoparticles ASPECT-RATIO Acoustic waveguide DISCRETE-DIPOLE APPROXIMATION CLUSTER Semiconductor superlattices Effective properties Acoustic shock waves Gallium arsenide Acoustic metamaterials Acoustic filters Cavity Electroreflectance Acoustical vortices Integration Ab initio calculations Laser ultrasonics Phononic crystal Chaos Thin films Thermal diffusivity Surface acoustic waves Silicon Brillouin light scattering GaAs Brillouin spectroscopy Band structure Mechanical properties Heat pulse Faraday rotation Bessel functions FTRaman CPA Backward wave Band gap Acoustic phonons Acoustic wave phenomena Hydrogen bond Picosecond ultrasonics Diamond anvil cells Aluminium compounds Copper nanowire High-speed optical techniques Neodymium compounds Acoustic wave reflection Acoustic Acoustic solitons Time resolved spectra Epitaxial layers Acoustical tweezers Acoustic metamaterial Elemental semiconductors Dielectric properties Broadband sound attenuation Elastic properties Elastic characterization Acoustic wave velocity Transition metal nitrides Focusing Acute lymphoblastic leukemia Acoustic propreties of solid ENHANCED RAMAN-SCATTERING Band gaps Dispersion Nonlinear acoustics High-temperature effects Elastic constants Thermal conductivity Au nanowires Alloying Ballistic heat transfer Elastic properties of nanogenerators Equation of state Asoustic vibration in nano-object Echo Magnetic semiconductors Guided waves Guided phonons HYDROXYL RADICALS
