Conception conjointe de l'optique et du traitement pour l'optimisation des systèmes d'imagerie - Thèse de l'Institut d'Optique Graduate School Accéder directement au contenu
Thèse Année : 2018
Joint optical-digital design for imaging system optimization
Imaging systems are now complex instruments where lens, sensor and digital processing interact strongly together. In order to obtain better imaging performance than conventional imaging, it has become necessary to take into account this interaction in the design stage and therefore to optimize jointly optical and digital parameters. The objective of my thesis is to develop joint optical-digital optimization methods in order to obtain imaging systems with higher performance and lower complexity. I first considered extending the depth of field of an already existing lens. A binary phase mask has been inserted in the vicinity of the aperture stop of a f/1.2 lens, and it has been optimized jointly with a deconvolution filter using the restored image quality criterion. The increase in depth of field has been quantified, and modulation transfer function measurements have proved experimentally the efficiency of this unconventional imaging system. During this first study only the phase mask was optimized. To further increase the imaging system efficiency, all the optical parameters need to be optimized. However, optical design is a complex problem in which specific constraints have to be taken into account and for which one needs to use a dedicated software. In this thesis I used the Code V optical design software. Since the image quality-based optimization cannot be easily implemented in this type of software, I proposed a new criterion. It is based on classical optical optimization criteria used in Code V that have been modified in order to take into account deconvolution in a implicit manner. This design method has been first validated on the optimization of a phase mask for depth of field extension of an already existing lens. Results were similar to those given by the image quality-based optimization. Then this method has been used to enhance a very fast f/0.75 lens: by modifying its optical parameters, the lens has been simplified, and the image quality has been homogenized over the field. Eventually I applied this joint design method to solve the important problem of thermal sensitivity of an 8-12 µm infrared system. By using this method I designed from scratch several types of short and long focal length athermalized lenses. The obtained lenses are simpler than conventionally athermalized ones while having similar or even higher imaging performance.
Aujourd'hui, les systèmes d'imagerie sont des instruments complexes qui font interagir optique, détecteur et traitement numérique. Afin de dépasser les performances d'imagerie conventionnelles, il devient nécessaire de tenir compte de cette interaction dès la phase de conception et d'optimiser simultanément les paramètres optiques et numériques. L'objectif de ma thèse est de développer des méthodes d'optimisation conjointe pour obtenir de nouveaux systèmes à performances d'imagerie augmentées et de complexité réduite. J'ai tout d'abord étudié le cas de l'augmentation de la profondeur de champ d'une combinaison optique existante. Un masque de phase binaire a été inséré au voisinage du diaphragme d'ouverture d'un objectif ouvert à f/1.2 et a été optimisé de façon conjointe avec un traitement de déconvolution en utilisant le critère basé sur la qualité de l'image restaurée. L'augmentation de profondeur de champ a été quantifiée et des mesures précises de la fonction de transfert de modulation ont permis de valider expérimentalement l'efficacité de ce type d'imageur non-conventionnel. Dans ces premiers travaux, seul le masque de phase a été modifié lors de l'optimisation. Pour accroître encore l'efficacité du système d'imagerie, il est nécessaire d'optimiser l'ensemble de tous les paramètres optiques. Or l'optimisation d'une combinaison optique est un problème complexe qui doit tenir compte de contraintes spécifiques et nécessite l'utilisation d'un logiciel de calcul optique dédié, comme le logiciel Code V qui a été utilisé dans cette thèse. Comme le critère d'optimisation conjointe basé sur la qualité image n'est plus adapté à ce type d'optimisation, j'ai proposé un nouveau critère. Il se base sur les critères d'optimisation classiques de Code V, qui ont été modifiés de façon à prendre en compte de manière implicite le traitement de déconvolution. Cette méthode de conception a tout d'abord été validée dans le cas de l'optimisation d'un masque de phase pour l'extension de profondeur de champ d'une combinaison optique existante. Les résultats obtenus sont équivalents à ceux donnés par l'optimisation suivant le critère de qualité d'image. La technique a ensuite été utilisée pour améliorer une combinaison conventionnelle existante à très forte ouverture (f/0.75) : en modifiant ses paramètres optiques, la combinaison a été allégée et la qualité d'image a été homogénéisée sur l'ensemble du champ. Enfin, j'ai appliqué cette méthode de conception conjointe pour résoudre le problème important de la sensibilité thermique d'un système infrarouge dans la bande 8-12 µm. Cette méthode a permis de concevoir, à partir de zéro, plusieurs types de combinaisons optiques à courte et longue focale, rendues insensibles à la température. Elles présentent un schéma optique plus simple que les solutions athermalisées de façon classique, tout en ayant des performances d'imagerie similaires voire supérieures.
71400_BURCKLEN_2018_archivage.pdf (21 Mo) Télécharger le fichier
tel-02918118 , version 1 (20-08-2020)
  • HAL Id : tel-02918118 , version 1
Marie-Anne Burcklen. Conception conjointe de l'optique et du traitement pour l'optimisation des systèmes d'imagerie. Optique [physics.optics]. Université Paris Saclay (COmUE), 2018. Français. ⟨NNT : 2018SACLO001⟩. ⟨tel-02918118⟩
206 Consultations
584 Téléchargements
